Avro Lancaster
26 Aug 2014 10:41 #271 by YellowPinkie
Replied by YellowPinkie on topic Avro Lancaster
I doubt they will fly it now, they make too much money from the taxi runs
They appear to be pressing on with it:
www.lincsaviation.co.uk/news/lancaster-n...ht/lancaster-ndt.htm
26 Aug 2014 12:48 #272 by Harboda77
Replied by Harboda77 on topic Avro Lancaster
We drove down to Hullavington on a very wet Sunday in 1970 to see if we could catch sight of the bomber and it was over three decades later before we finally saw it at East Kirkby.
My understanding from our tour guide at East Kirkby was that the restoration to flying condition would be a task for the next generation ~ as their principle objective had been limited to a static memorial to one of the farmers brothers.
Having four working engines working and their now famous taxi runs had exceeded the original intentions.
Their principle concerns for the future ( at that time ) had been what would happen to the plane once the original team had passed away ~ They did not want it to gather dust in a remote location.
We were told that the owner had not considered a full restoration to flying condition however if this would ensure the bombers future then they would not object to any future planning or fund raising.
The discussion that followed on it becoming a flying memorial revolved around the main spar ~ as their existing one may have been considered time expired and it would need replacing.
They apparently owned one new spar and the discussions ( at that time ) revolved around should it be kept or offered to the memorial flight if they needed one to ensure that City of Lincoln was kept flying.
The remarks made at the conclusion of our tour had been that the increase in revenue seen as a result of the heritage movement could bring this discussion forward by a decade and it might even be possible to consider seeing the bomber airworthy by 2020 to 2025.
Our visit must have been around 2004 so its great to see that they are still moving forward.
27 Aug 2014 15:39 #273 by canberra
Replied by canberra on topic Avro Lancaster
When was City of Lincoln re-sparred? And does anyone know how many hours to its next one?
27 Aug 2014 16:08 #274 by Harboda77
Wiki records 1995 assuming that that was the first time then that would make it nearly 40 years ?
en.wikipedia.org/wiki/Avro_Lancaster_PA474
Does any one know the true reason for the heritage industry not being able to make cast another one ?
Dave.
27 Aug 2014 19:35 #275 by Peter Kirk
Replied by Peter Kirk on topic Avro Lancaster
Never thought about how a main spar was made but I would imagine it was made from rolled sections welded to cross sections rather than a single piece as the name would suggest.
28 Aug 2014 09:01 #276 by PETERTHEEATER
Replied by PETERTHEEATER on topic Avro Lancaster
Almost certainly a fabricated (rivetted) box section from light alloys with internal formers. The outboard wing spars would have been tapered fabrications attached at the start of the dihedral. The metal thickness (gauge) would have been selected to provide the required strength using the minimum acceptable to conserve weight.
As the main structural component to which everything else was attached directly or indirectly it would be the target for fatigue and, therefore, given a life in flying hours. Landings too would stress the mainspar through the landing gear attachments and should have been factored in. They didn't install Fatigue Meters in operational service so the assessed life would have been quite conservative due to the need to apply a generous safety margin.
29 Aug 2014 11:13 #277 by stevie
Replied by stevie on topic Avro Lancaster
'Vera' won't be flying this weekend sadly. Hopefully the problem will be sorted ASAP -
From Lancaster Bomber on Facebook:
"During a local flight this morning from Durham Tees Valley Airport this morning, the Canadian Lancaster performed a precautionary engine shutdown. The aircraft landed safely without incident.
It is now hangared and undergoing maintenance. Regrettably she will not attend our weekend events and will advise on others".
29 Aug 2014 13:17 #278 by YellowPinkie
It looks like I'm destined to not see her fly. Bournemouth on Sunday...
Word is it is an oil leak, so I've got my fingers crossed she'll be up and running for Sunday.
www.thenorthernecho.co.uk/news/11440994....gine_shutdown_drama/
29 Aug 2014 17:35 #279 by Chris Lowe
Replied by Chris Lowe on topic Avro Lancaster
I had nice view when the BBMF Lanc flew over my garden yesterday.
29 Aug 2014 22:29 #280 by Harboda77
I contacted BBMF and they kindly provided the following information on the subject of the main Spar replacement.
The Lancaster had its main spar replaced in the winter of 1995/6 and it was the only time it has been replaced, they don't really have a life span its more down to the stress on the spar causing fatigue , so for instance if the Lancaster had be flying at full bomb laden capacity it wouldn't have lasted anywhere near as long as that. It is quite well looked after never fuelled to capacity with the banking in the turns strictly limited to try and make it last as long as possible.
If this component were the one critical longevity item then City of Lincoln could still be airworthy beyond 2035 ?
Assume that they can perform non destructive testing with ultrasound.
I wonder what happened to the original spar ?
