Panavia Tornado
13 Dec 2017 17:21 - 13 Dec 2017 17:26 #1 by stevie
Panavia Tornado was created by stevie
I'm surprised there hasn't already been a thread dedicated to the Tornado here in the Aircraft threads. With the aircraft in the twilight of it's flying career it seems only right that there is one.
Feeling the need to make the most of the aircraft whilst it's still in service I ventured off to Marham to watch them in action a few weeks back -
Steve
The following user(s) said Thank You: Bomber, netcompsys, PaulGiverin
13 Dec 2017 20:06 #2 by PaulGiverin
Replied by PaulGiverin on topic Panavia Tornado
I was a fairly young airman when they came into service and there were a lot of doubters then but it has given sterling service. I spent a few years working on them, on XV sqn, II (ac) sqn and a couple of engine bay tours. Many years later I worked on them again as a civvy at Marham. It will be a sad day when they finally go out of service.
The following user(s) said Thank You: stevie
13 Dec 2017 22:26 #3 by REF
Replied by REF on topic Panavia Tornado
Steve
Did you go Via Lakenheath for the F-15's!.......... ;-)
14 Dec 2017 06:46 #4 by PETERTHEEATER
Replied by PETERTHEEATER on topic Panavia Tornado
During development, Tornado was referred to as MRCA (Multi-Role Combat Aircraft). The BAC Warton workforce knew it as Mother Riley's Cardboard Aeroplane:)
14 Dec 2017 10:33 #5 by canberra
Replied by canberra on topic Panavia Tornado
Oh no they didnt!!! Sorry if that sounds like a pantomime line.
MRCA at Warton and Salmesbury was referrred to as "Must Refurbish Canberra Again", and the Tornado was able to replace the Canberra in the high altitude PR role.
Having said that it has done a sterling job. And according to a documentary I saw recently it is the fastest aircraft in the world at low level, apparently it can do just over 900mph at 250 feet.
14 Dec 2017 10:49 #6 by Peter Kirk
Replied by Peter Kirk on topic Panavia Tornado
I understand there were quite a few variations on the MRCA acronym. I also acquired a few publicity brochures in the early seventies, some from Farnborough airshows and some from other sources. Sadly they were all disposed of, along with my 1968 Concorde development chart, when I moved in with my, then, girlfriend. They didn't seem important then!
14 Dec 2017 10:52 #7 by canberra
And Tornado wasnt going to be what it was called. Originally the name suggested was Panther, Im guessing that like Typhoon a name was chosen that was the same in German and Italian.
Mind you the Italians do tend to refer to it as PA 200.
14 Dec 2017 16:46 #8 by Burleysway1
Replied by Burleysway1 on topic Panavia Tornado
Will certainly miss the Tornado when it finally bows out of service. The F3 is my favourite fighter.
14 Dec 2017 18:57 #9 by PaulGiverin
The F3 wasn't really a fighter, more of an interceptor. Unlike the GR, it never proved itself in combat. In GW1 it was kept well out of the way.
14 Dec 2017 22:02 #10 by StuartBr
Replied by StuartBr on topic Panavia Tornado
I did a bit on the Tornado during my apprenticeship at Brooklands. The Tailerons were manufactured there. Some seriously impressive machining. The skin panels were machined from solid with if my memory serves me correctly a 48 hour machining cycle. The panels were then shot peened and pressed to shape before bolting and riveting together with the inner rib. This had a very substantial bearing where it pivoted against the fuselage.
The following user(s) said Thank You: GTrider
