Hawker Hunter
06 Dec 2013 11:46 #1 by ww2nut
Hawker Hunter was created by ww2nut
Very strange that my small Welsh village by the coast, now has a Spitfire AND a Hunter in the local ATC, newly painted for the better !!
in a non aviation area, we have 2 super stars of the sky ...go figure !
20 Dec 2013 21:34 #2 by Guest
Replied by Guest on topic Hawker Hunter
With regards to what paint was used on RAF Waddington 8 Squadron's Hawker Hunter XE606/620.
Dacrylate product
Vinaprime post abrasive work, Primer 'Buff-primer' adaptor-coat to seal in previous coating which it appear to hold-in.
Dacthane (gloss finish) Urethane Alkyd Enamel
Dacthane was Green-Grey- also roundels -bars. Black nose and tail fin item Dacthane again only in 'Eggshell' finish.
Dacrylate of Sutton-in-Ashfield Nottingham
NA
28 Mar 2014 20:59 #3 by Peter Kirk
Replied by Peter Kirk on topic Hawker Hunter
Non- aviation area? You got Margam Sands and Porthcawl ranges just down the road :)
02 Apr 2014 18:32 #4 by ww2nut
Replied by ww2nut on topic Hawker Hunter
and stormy down but its hardly Duxford or a kent village, its just strange that we have these 2 aircraft in a typical welsh village
03 Apr 2014 18:01 #5 by REF
Replied by REF on topic Hawker Hunter
What a difference a few years, and a museum makes...
The famous XG194 at North Luffenham on 16 August 2009
The same aircraft, restored to the scheme worn by The Black Arrows at Wattisham yesterday, 2 April 2014
03 Apr 2014 18:25 #6 by Alex Brown
Replied by Alex Brown on topic Hawker Hunter
Looks great, unrecognizable!
I wonder if they will let me sit in it so that I can get a then and now photo?
04 Apr 2014 09:47 #8 by ww2nut
with issues about entry to the airfield after hours i believe the gates may soon open to the public assuming more business continues to use the airfield, could become the coolest industrial estate ever !!
04 Apr 2014 11:23 #9 by mawganmad
Replied by mawganmad on topic Hawker Hunter
Hi Rich, many of the Hunters (and other jets) aren't based here as such, but come in and out for maintenance, both XF515 and XF357 belong to the Dutch Hawker Hunter Foundation at Leeuwarden. Unfortunately I've only seen '515 the once.
Miss D, WT723 and XL573 along with T.8M XL602 (in bits) are based at Saints though.
WW2nut, not sure what you mean there or whether you mean St Athan even, but as long as the MoD and SF is here I don't think the gates will be opening.
04 Apr 2014 17:43 #10 by REF
Its becoming the Coningsby for classic jets!
