Forum
Open Forum
Miscellaneous Research Topics
Aircraft
Aero-Commander was Norman Brittain Islander ?
Scammell Amazon
Topic Author
Offline
Senior Member
Less
More
Thank you received: 9
14 May 2016 19:52 - 14 May 2016 19:56 #1
by Scammell Amazon
This message has an attachment image. Please log in or register to see it.
Last edit: 14 May 2016 19:56 by Scammell Amazon .
Less
More
Thank you received: 195
14 May 2016 20:41 #2
by John Anderson
Britten Norman Islander? Undercarriage does not look right-should be twin wheels on the main legs. Mind you my last contact with the Islander was in 1972 so could be wrong.
Less
More
Thank you received: 1029
14 May 2016 21:09 - 14 May 2016 21:11 #3
by Peter Kirk
Looks like a nose wheel fitted in place of the original, although the wings look wrong for an Islander anyway. It does look funny without the trousers
Last edit: 14 May 2016 21:11 by Peter Kirk .
WJT
Visitor
15 May 2016 05:01 #4
by WJT
Deffo not an Islander. Fuselage from a Rockwell Commander (?) with truncated wings.
PETERTHEEATER
Offline
Platinum Member
Less
More
Thank you received: 772
15 May 2016 07:16 #5
by PETERTHEEATER
The following user(s) said Thank You: Scammell Amazon
Less
More
Thank you received: 122
15 May 2016 10:30 #6
by canberra
No not a BrittenNorman(or is it Britten-Norman?) Islander, as has been said earlier an Aero Commander with truncated wings.
PETERTHEEATER
Offline
Platinum Member
Less
More
15 May 2016 11:07 #7
by PETERTHEEATER
If you look at the nearest wing where it joins the engine nacelle you will see a rib of the full chord wing painted over. A 'stub' wing has been attached presumably the 'tip' of the original mainplane. A non-flier I hope!
Less
More
Thank you received: 99
15 May 2016 19:51 #8
by daveg4otu
Aero-Commander 500or 520 .Presumably this is an eye-catcher somewhere in France ...where?
Less
More
Thank you received: 157
16 May 2016 09:38 #9
by IanDDavidson
557 Rue de la Folie, 76850 Bracquetuit, France
Less
More
29 Aug 2017 13:35 #10
by avion ancien
Google Earth suggests that it's not there now.
Pas un ringard, je t'assure!
Forum
Open Forum
Aircraft
