Gunnite
05 Apr 2009 11:19 #1 by Ballyhalbert
Gunnite was created by Ballyhalbert
I have in my possession a copy of the Station Diary for RAF Ballyhalbert.
On 7th January 1943, a strong letter of complaint was sent to RAF HQ regarding the deplorable state of all brick buildings which were letting in water following heavy rainfall. The airfield had only been open for around 18 months, having opened on 28th June 1941. The following entry appears in the Station Diary in response to the above letter:-
26/1/1943:- Station Headquarters Building treated with "Gunnite" as an experiment to prevent rain penetrating the walls.
I can find no other entries in the Diary relating to this issue.
Can someone explain what exactly "Gunnite" is or was, and how it worked?
Many Thanks
David
05 Apr 2009 11:32 #2 by Peter Kirk
Replied by Peter Kirk on topic Gunnite
I believe it is a sprayed surface treatment.
05 Apr 2009 17:13 #3 by carnaby
Replied by carnaby on topic Gunnite
I thought it was what an Australian said when he wished you farewell :lol:
05 Apr 2009 17:33 #4 by mawganmad
Replied by mawganmad on topic Gunnite
:lol: Nice shooting soldier! :lol:
05 Apr 2009 18:30 #5 by DG1
Replied by DG1 on topic Gunnite
What is Gunnite?
Gunnite is “mortar conveyed through a hose and pneumatically projected at High velocity on to a surface” *-ACI
Why is it different from conventional concrete?
Unlike conventional concrete, which is first placed and then compacted (vibrated) in a second operation, gunnite undergoes placement and compaction at the same time due to the force with which it is projected from the nozzle. Because of this it is more dense, homogeneous, strong and waterproof than any other process.
Gunnite is not placed in forms, it can be impacted onto any type of shape Of surface, including vertical or overhead.
See here.
www.sangerssilo.com/Gunnite.html
Live Your Dream Ask Me How.
www.bazjasp.co.uk
06 Apr 2009 05:48 #6 by PETERTHEEATER
Replied by PETERTHEEATER on topic Gunnite
Lamella Sheds (Hangars) were 'Gunited' externally during construction.
In modern day construction ann example of use is for large swimming pools where - as with Lamella Sheds - it is sprayed into bases and elevations formed with reinforcing bar mattresses. Used a lot in the USA.
29 Jul 2009 11:54 #7 by Ballyhalbert
Replied by Ballyhalbert on topic Gunnite
What is Gunnite?
See here.
Thanks for that.
