Re-fueling areas
12 Apr 2009 13:36 #1 by REF
Re-fueling areas was created by REF
Here are a few phtoos of the re-fueling area at Woodbridge, I am not sure what the various things are though!
I think it was the 'hot' refueling area.
12 Apr 2009 20:14 #2 by stevfire2
Replied by stevfire2 on topic Re-fueling areas
the first two appear to show a non-aspirating fire fighting monitor.
13 Apr 2009 08:05 #3 by WJT
Replied by WJT on topic Re-fueling areas
Stevfire2: That was my thought, presumably to dump foam onto the refuelling pit in the event of an accident. The refuelling pit seems to have a sliding lid - wonder if REF got any shots from inside the pit?
13 Apr 2009 08:14 #4 by REF
Replied by REF on topic Re-fueling areas
It is really just the photos I have put up WJT - none of the insideof the pit.
13 Apr 2009 08:25 #5 by WJT
I thought that would be the case Richard. If you ever get the chance to go back, it would be very interesting to see inside that pit with the sliding roof.
I'm sure you are right that this is a hot refuelling area, with the weight of the hose being carried on the little set of wheels. I suppose that the questions this raises are numerous. For example, was it put in for the Phantoms or the A-10s? Were similar facilities installed at Bentwaters and the other USAF airfields? And then there is the never discussed subject of refuelling hydrant systems at RAF airfields. Roll on the upgraded website and the new section on airfield facilities!
13 Apr 2009 08:55 #6 by Paul Francis
Replied by Paul Francis on topic Re-fueling areas
I was under the impression that, at Alconbury in the 1970s a set of aircraft hardstands had a shared refuelling point, set into the concrete slab. But these were done away with when the Tab Vees were built. I may be wrong about this, shall have to check the plans if I can find them.
13 Apr 2009 09:00 #7 by mawganmad
Replied by mawganmad on topic Re-fueling areas
Interesting pics REF, first couple definately look like fire fighting kit, third pic you can see a BFI and control building.
18 Apr 2009 13:07 #8 by Ant1981
Replied by Ant1981 on topic Re-fueling areas
Looks like where the station fire section do their fire training, where they would have a module connected to a fuelling system to ignite the model into flames and practice fighting the fire.
Military Airfield Lighting and Controls Technician. Keen photographer and quite partial to a V8 engine.
18 Apr 2009 13:47 #9 by mawganmad
Not that close to a bulk fuel installation or tower it won't be!
18 Apr 2009 14:48 #10 by Ant1981
Actually, yeah it will be that close to the tower, it's not even really close to be honest. And there's no BFI near it, just looks like the fuelling parts for the fire trainer. I know this from experience of working at active airfields, seen it loads of times.
