Weston-on-the-Green
09 Jan 2020 10:59 #1 by OneEighthBit
Weston-on-the-Green was created by OneEighthBit
Old returning member here!
Can anyone possibly help me out regarding Weston-on-the-Green. I'm trying to find a photo or better yet RAF site plan that shows where the blister and bessonneau hangars were located.
Or rather, I sort of know where they were but I need to "proof". I'm aware of some hard standings off the taxiway which I assume where hangar bases and I've seen a 1951 photo were one blister hangar is extent but I'm looking for something war-time.
Appreciate any help.
09 Jan 2020 12:20 #2 by Peter Kirk
Replied by Peter Kirk on topic Weston-on-the-Green
I only have two poor copies of wartime Weston on the Green. The first is an aerial from April 1942 taken through a very shiny plastic cover that couldn't be removed. The plan is from 1945 and is one of those copies of the larger RSP that didn't include the building index.
The following user(s) said Thank You: OneEighthBit
09 Jan 2020 12:34 #3 by netcompsys
Replied by netcompsys on topic Weston-on-the-Green
There is an oblique aerial photo on Brtain from above which shows a partial view of the airfield from the south, dated 1947 which shows 5 blisters
www.britainfromabove.org.uk/en/image/EAW012195
( if you have an account you can zoom in and get a better view)
09 Jan 2020 12:52 #4 by OneEighthBit
Replied by OneEighthBit on topic Weston-on-the-Green
Thanks both! That was just what I was looking for.
Looking at the ORB for No.2 GTS it seems apparent that when they moved in the airfield needed to be expanded for accommodation and hangarage as well as the perimeter track built. That seems to show in the difference between the photo and the plan quite nicely. I guess the bessonneau hangars came down quite quickly as they were meant to be a temporary solution.
09 Jan 2020 15:35 #5 by netcompsys
If you were looking for other photos to illustrate or add interest then this from th IWM shows Hotspurs and a hangar
www.iwm.org.uk/collections/item/object/205023010
A search of the collection " weston green" brings up some other photos that might be of interest
