Lindholme Radio Tower
09 Feb 2020 22:49 #1 by G4HFG
Lindholme Radio Tower was created by G4HFG
Situated at the North side of the airfield was the bomb dump. On this site in the 1980's there was a large truncated radio tower which could been seen from miles around both. The tower sported UHF stacked dipoles at each corner of the tower. Lindholme and Northern Radar were disused at that time (though Northern Radar was on a care & maintenance program ). When the tower was removed a mobile phone mast was put in its place.
Similar very distinctive truncated towers all with the same 4 uhf stack antennas could be seen several sites in the UK around that time not necessarily near to active airfields .
Does anyone know what the purpose of these radio towers was please?
Thank you in anticipation.
10 Feb 2020 09:37 #2 by mbriscoe
Replied by mbriscoe on topic Lindholme Radio Tower
I presume they are ground to air Tx or Rx. I have seen sites with both VHF and UHF ones, presumably normal civil channels and military channels. The military often have the small omni-directional conical antenna but I have seen a larger version - we used to see them lying about on the ground at one CAA site we visited because there was a site sharers' room used by an organisation we did work for. I presumed they were faulty ones that had been dumped.
I have also seen what looked like the antenna we used for broadcast TV, a fibre glass cylinder that would have a series of stacked dipoles inside. These are smaller but I did wonder if they similarly enclosed stacked dipoles.
10 Feb 2020 11:56 #3 by canberra
Replied by canberra on topic Lindholme Radio Tower
As Lindholme was a Bloodhound control station I wonder if thats what this tower is from?
10 Feb 2020 12:05 #4 by G4HFG
Replied by G4HFG on topic Lindholme Radio Tower
Thank you for your reply . I am familiar with the military uhf/vhf ground to air antennas, however these were not this type, hence my curiosity.
I have attached a snapshot of the stacked dipoles which were on each corner of the truncated tower at Lindholme . These are normally associated with ground to mobile or person to person and similar to the ones used by the Police at that time.. We just thought that it was odd to see such a substantial structure with 4 of this type on top and this was repeated at numerous places in the UK at that time.
Cheers,
10 Feb 2020 12:38 #5 by canberra
Ive never seen an aerial like that so cant help, we could do with some ex ground radio people on the site. One thing that springs to mind is could it be anything to do with 840 Signals Unit? This was formed at Lindholme after the airfield closed and was here until the mid nineties.
10 Feb 2020 12:48 #6 by 698
Replied by 698 on topic Lindholme Radio Tower
They look like standard UHF "PMR" aerials. 455 MHz or thereabout.
They may be phased together to give a particular pattern. ie cardioid.
They are very common, most shopping centres have them for shop watch etc
10 Feb 2020 15:37 - 10 Feb 2020 15:38 #7 by PETERTHEEATER
Replied by PETERTHEEATER on topic Lindholme Radio Tower
The radio mast was here (Top lefthand corner)
10 Feb 2020 18:00 #8 by G4HFG
You have the location of the radio tower correct , thank you. It has now been replaced by a mobile phone mast in almost the same place.
These types of antennas in that era would normally have covered a frequency range of between 400 to 470 MHz. However, UK airfield ground comms (RAF) did not use this spectrum.
I concede that this could have been related to Northern Radar and 840 Signals or in the days when it was a TCC for Bloodhound. However, I did note that these could be seen at other places that were not directly related to Bloodhound .
It could simply be that when the RAF and 840 Signals were leaving, the Home Office commandeered the tower for the Police personal radios, as an infill to cover Hatfield Woodhouse, Lindholme and Finningley. I have before never seen an RAF radio (substantial) mast built on a bomb dump though!
10 Feb 2020 19:08 #9 by mbriscoe
The antenna does not look all that old, perhaps a few tens of years. It is rather like the ones you used to see for Airwave.
10 Feb 2020 20:02 - 10 Feb 2020 20:07 #10 by Sparky67
Replied by Sparky67 on topic Lindholme Radio Tower
The antenna is indeed UHF and is what we knew as an SA460 or CDF450 'in the trade', dependant on manufacturer. With the elements stacked and phased in that way they are more directional than omni (with 8dB peak gain). They had a reasonable bandwidth and were widely used by the police on their UHF divisional systems up to the mid-2000s. Now used on some Airwave sites, among others.
Does its direction provide a clue as to the intended coverage area?
Martin
