Spraying from the air
26 Feb 2010 09:36 #1 by PETERTHEEATER
Spraying from the air was created by PETERTHEEATER
An aircraft installation intended for spraying chemicals such as mustard gas and phosgene from the air was the SCI or Smoke Curtain Installation. Naturally, at the time, this was a cover.
I found this image in USA NARA of a Havoc laying a 'smoke screen' probably a practice sortie in the use of SCI for CW.
CAPTION:
26 Feb 2010 12:48 #2 by Peter Kirk
Replied by Peter Kirk on topic Spraying from the air
I like the wording of the text. Seems like the A-20 was a war winner. We should have used more of them :)
I am also intruiged by the "important weight of bombs". What is an unimportant weight then?
I wonder how effective smoke laying was in practice.
26 Feb 2010 13:56 #3 by P Bellamy
Replied by P Bellamy on topic Spraying from the air
20FG at Kingscliffe did infantry support smokescreen-laying trials with P-51D Mustangs. I'll see if I can find a photo of one whipping along at zero feet.
26 Feb 2010 14:11 #4 by OneEighthBit
Replied by OneEighthBit on topic Spraying from the air
I think Operation Banquet was the plan to spray the British beaches with chemicals/gas in case of invasion. Most units had a "Banquet Plan" which was a list of personnel who, in the event the plan was put into operation, were to report immediately to certain stations to crew up and undertake the spraying in second-line aircraft.
I learnt all this after finding the plan for Stoke Orchard which had only one hapless chap on the list to report to a bombing station if it all went off! :D
26 Feb 2010 15:48 #5 by carnaby
Replied by carnaby on topic Spraying from the air
I suspect it was actually the conversion of training aircraft into bombers, e.g.
AIR 14/1126 "Operation "Banquet": scheme to employ all available training aircraft in defence of UK against invasion 1940 May - Nov.
I note relevant records continue into 1943.
Looks interesting will investigate if the TNA opportunity arises.
There were other 'Operation Banquets' later in WWII, and the Navy had: ADM 1/13530 Operation "Banquet Ceiling": disposal of ammunition, bombs, etc 1942-1943
27 Feb 2010 06:36 #6 by PETERTHEEATER
Replied by PETERTHEEATER on topic Spraying from the air
You forgot the "capable of extreme speed" :-D
07 Sep 2013 13:02 #7 by P Bellamy
8AF 1st Bomb Division CWS history:
October 1943
The obtaining of the RAF secret bomb, technically designated as SCI type S/L four hundred (400) lbs. Mk.1A, but commonly known as the "Flying Cow", for use by us as a potential Skymarker, was attempted. It was believed that a filling of our smoke munition, "FS", would produce a readily visible smoke trail at high altitudes and serve as a smoke signal for our formations.
The "Cow" filled with "FS" was satisfactory, even at thirty-one thousand (31,000) ft. and after conclusively proving that it was readily adaptable for our release, it was disapproved by the Air Ministry on the grounds that its construction, etc., was of such a secret nature that it would not be used under any circumstances other than Offensive Gas Warfare.
07 Sep 2013 13:27 #8 by PETERTHEEATER
Thanks Paul. I thought that the USAAF would have been looking at ways to eliminate vapour trails at altitude since thay gave a visible signature to the enemy.
But, it does correct my assumption that the 'plane shown in my Post #1 was using smoke for CW practice.
07 Sep 2013 14:28 #9 by P Bellamy
SCI operation diagrams:
Source: AFHRA via 1AD Archive
07 Sep 2013 15:21 #10 by Alex Brown
Replied by Alex Brown on topic Spraying from the air
Even in the event of invasion that would presumably have been "illegal"?
