RAF Operations Clock
26 Apr 2010 10:25 #1 by Jayfoe
RAF Operations Clock was created by Jayfoe
Not sure if this is the right section to post this in but here goes.....
After a recent visit to Digby Ops room we were discussing the Ops Clocks and someone highlighted something I've never noticed before, namely the direction the red/blue/yellow arrows round the outside point. If you check this link:
home.earthlink.net/~modguide/opsroom.html
You can see both designs, the big picture of the clock at the top of the page has the triangles pointing out and the one on the wall of the Uxbridge Ops room has the arrows pointing in. At the end of the discussion we came up with 2 theories:
1) 2 companies were tasked with building the clocks and before the joys of computer design each company interpreted the contract/design differently; or
2) At some point, someone decided that the clock would work better if the triangles pointed the other way.
If anyone can shed any light on this it would be most appreciated and allow us to get on with our work!
Jay
26 Apr 2010 10:42 #2 by carnaby
Replied by carnaby on topic RAF Operations Clock
An interesting observation, Jay. I've just noticed that the clock in the link - triangles out - has 12 of them, whereas the replica on my wall - triangles in - has 24.
Hmm :confused:
26 Apr 2010 18:31 #3 by P Bellamy
Replied by P Bellamy on topic RAF Operations Clock
...whereas the replica on my wall - triangles in - has 24.
Without seeing yours, I'd guess the triangles are very pointy.
Chances are the replica dial is based on the post-war ROC Sector Clock, the triangles being made narrower to correspond with the higher speed of jets to be plotted.
27 Apr 2010 11:52 - 24 Dec 2017 22:04 #4 by carnaby
Without seeing yours, I'd guess the triangles are very pointy. Chances are the replica dial is based on the post-war ROC Sector Clock, the triangles being made narrower to correspond with the higher speed of jets to be plotted.
Bezel and glass removed to obviate reflections.
Useful info, Paul. What a disappointment - just compared it with 12 sector varieties. Mine isn't nearly as good. Feel ripped off - I've had this a long time - can't remember where it came from.
27 Apr 2010 12:17 #5 by P Bellamy
Here's one of the battery-powered lookalikes I made recently:
29 Apr 2010 09:31 #6 by PETERTHEEATER
Replied by PETERTHEEATER on topic RAF Operations Clock
Sniff. Looks very Seikoish. The one that I made I put the name of a well known Swiss horological company. Great invention CAD!:-D
10 Nov 2010 12:34 #7 by ricead
Replied by ricead on topic RAF Operations Clock
Type III where introduced towards the end of WWII and continued in service until the 50s. They had the inward facing triangles at spaces of 2.5 minutes due to the faster response times being achieved. I think both look good.
11 Nov 2010 19:50 #8 by canberra
Replied by canberra on topic RAF Operations Clock
Anyone know if you can buy US Navy 24 hour analogue clocks???
11 Nov 2010 20:07 #9 by mawganmad
Replied by mawganmad on topic RAF Operations Clock
So is this the second type?
12 Nov 2010 15:39 #10 by P Bellamy
That looks from the outside to be a Type I.
Type IIs usually have a slot for an advance-retard adjuster between the Crown and the RAF wreath.
