Bleach Bath question
03 May 2010 15:38 #1 by ww2ni
Bleach Bath question was created by ww2ni
Is there any particular reason why Airborne Soldiers would require a bleach bath?
I have found a sign saying this and suspect it may have something to do with parachures but not sure.:confused:
03 May 2010 16:18 #2 by kebecker
Replied by kebecker on topic Bleach Bath question
Bleach was/is/can be used to decontaminate clothing, equipment etc following exposure to some chemical agents. Is your sign at all connected with a gas decontamination block?
03 May 2010 17:42 #3 by canberra
Replied by canberra on topic Bleach Bath question
Thats what I was going to say. In the UK it was called bleach slurry, basically used to decontaminate vehicles, and I think aircraft. But isnt bleach corrosive?
03 May 2010 17:43 #4 by ww2ni
Replied by ww2ni on topic Bleach Bath question
Hi,
I found the sign in an out-building at Killymoon Castle at Cookstown which was a base used by 82nd Airborne during the Second World War prior to D-Day.
I will get it downloaded and put on the site.
03 May 2010 19:16 #5 by kebecker
Used at a pH of less than 10 and washed off immeadiately, probably not that corrosive
03 May 2010 21:03 #6 by carnaby
Replied by carnaby on topic Bleach Bath question
Google it and you'll find that large numbers of females use it regularly for hair modification in one way or another !
04 May 2010 06:58 #7 by PETERTHEEATER
Replied by PETERTHEEATER on topic Bleach Bath question
Hair bleach is usually a solution of Hydrogen Peroxide,(once used as torpedo fuel oxidant!) but the bleach used for mustard gas contamination was (is) Sodium Hypochlorate although I accept that some household products contain a mix of both. The latter was mixed with kaolin - China Clay - (I think to form a paste applied to the body and then showered off. Clothes were discarded and collected for separate decontamination by washing.
04 May 2010 09:01 #8 by ww2ni
Vehicle decontamination sounds right as there is an inspection ramp nearby so I am guessing this was an MT Section.
04 May 2010 17:58 #9 by canberra
I think that bleach slurry might be a different compound to what waqs used in wwii. Did they really worry that much about gas in wwii?
05 May 2010 06:15 #10 by PETERTHEEATER
Yes, or Decontamination Centres and the UKs own production, storage and filling facilities for deterrent CW (Mustard) would not have been built.
Fortunately, perhaps because he himself was a WW1 victim of gas - Hitler never ordered the use of the CW in the German inventory which is just as well because the had Nerve agents too which the Allies knew nothing about.
Also, respirators (gas masks) were standard issue to both military and civilians earlier in the war.
