Drawing Airfield Layouts
04 Jun 2008 22:15 #1 by Peter Kirk
Drawing Airfield Layouts was created by Peter Kirk
My drawing skills are not up to much, despite having an 'O' level in technical drawing. I have had many goes at drawing from aerial photos, especially earlier wartime layouts but the result where of sketch quality, impatience being the main issue here. Anyway it oocurred to me the in this computer age there must be a simplier solution. Ignoring the obvious CAD solutions (it took me a day to draw a curve in one) my thoughts turned to Vector graphics, which, if my memory is correct, are scalable and rotatable without loosing quality, unlike JPG or BMP file which seem to degrade rapidly if turned through anything other than 90 degrees. The thought was to create constant scale components (hangars, pens, loops, hardstands etc) and buid a drawing that way - it works in Powerpoint for business use.
Does anyone know if this ever been attempted or indeed possible if so would it be difficult?
Peter
04 Jun 2008 22:27 #2 by CDP
Replied by CDP on topic Drawing Airfield Layouts
PNK,
I faced this very same problem for our first publication, whose subject matter is RAF Ashbourne & RAF Darley Moor, Derbyshire. After a few experiments, I managed to get things about right which were suitable for final publication.
What I did was scan the relevant image (in this case the general arrangement section of the record site plan) and save it as a .jpeg. Opened as a layer, I created a transparent layer over the top of it and, fiddling around with a lot of lines, managed to create the following. I did it in Macromedia Fireworks MX2004. The programme still stands up very well today, I might add!
It might be worth pointing out here that as it was for commercial publication, permission was requested, and given, from the RAF Museum after submitting sample scans and tracings.
General arrangement sketch, RAF Ashbourne, Derbyshire (adapted from A.M Drawing No. 1116/45)
Chris
04 Jun 2008 22:51 #3 by Paul Francis
Replied by Paul Francis on topic Drawing Airfield Layouts
The technique I use is to scan a original drawing and then trace it using Paint.net a free programe to download. Its very easy use and the results can be stunning.
05 Jun 2008 09:58 #4 by CDP
Trust me to make things difficult for myself then!!
Chris
05 Jun 2008 16:32 #5 by Peter Kirk
Replied by Peter Kirk on topic Drawing Airfield Layouts
Do you both use mice or graphics tablets?
I have edited photo's with a mouse and make much use of the undo button (Paintshop Pro 7.4 by the way) as I don't seem able to keep the control the on rounded bits.
Thanks for the advice it has been very helpful.
Peter
05 Jun 2008 17:02 #6 by Stevo
Replied by Stevo on topic Drawing Airfield Layouts
Hi
I sometimes do an airfield chart for my Flight sim addons. Here's one I did for my RAF Leuchars addon all done in Photoshop CS by hand (well mouse).
I've left it as a link because its a large image.
www.ukmil.org.uk/e107_files/publ ... e-char.jpg
Stevo ;)
05 Jun 2008 17:08 #7 by Paul Francis
Here is one i did earlier, obviously this is a jpeg and the detail and colour is shot but the original drawing is really good and bright. All done in Paint.net and for free!!
05 Jun 2008 17:18 #8 by Stevo
HI
Just had a look at the paint.net website and it looks very similar in layout to Photoshop even the tools menu has the same symbols and the History and layers menus are more or less the same.
Amazing considering its free, I think I'll download it and see how similar it is to Photoshop.
05 Jun 2008 18:00 #9 by Paul Francis
Paint.net has saved my life. Before it was available I used to draw airfield layouts by hand on myler - plastic film using pencil (0.35mm) and I got quite good at it. But then it was a trip to the photocopy shop to get a positive and then annotate the plan by spraying building numbers with spraymat etc. But now with Paint.net its so simple and a damn site quicker to produce great results.
05 Jun 2008 18:09 #10 by CDP
In answer to PNK's post, I personally use a mouse, although I have a drawing tablet somewhere.
I've also just had a look at paint.net's web site and seems an interesting piece of kit. As it's free, I think it'll be worth the download and give it a try. Thanks for bringing it up Paul.
Chris
