Anyone seen or heard of one of these? On 18 November 1946, the undercarriage of Wellington PF940 on charge to No 18 MU is recorded as having broken through a Leigh Light test pit while on tow at RAF Dumfries.
The Leigh Light anti-submarine searchlight when mounted in the Wellington aircraft was in a hydaulically retractable 'dustbin' so, I guess that on the ground there was insufficient clearance to extend it for testing and maintenance and that a simple lined pit was constructed over which the aircraft could be positioned. The pit would be covered when not in use.
The Catalina version was in an under-wing nacelle and the same problem did not arise in fact, the maintenance men needed ladders.
I know that 214 Squadron at Oulton used a pit similar to an MT inspection pit to load and remove their special radio kit from their B17's . There is at least one photograph out there showing this but I can't finds it at present !
I've found it ! It is in 'Secret Squadrons of the Eighth' , Carty , Ian Allan , 1990 on page 87 . Referring to the Jostle radio transmitter the caption reads ; 'When at the dispersal it was lowered into a specially dug pit. The aircraft was then brought over the pit and the jammer winched up into the bomb bay' . Photo credit is RSRE ; Royal Signals & Radar Establishment .
