Use of metal track on civil airfields
31 Jul 2008 19:25 #1 by Peter Kirk
Use of metal track on civil airfields was created by Peter Kirk
Looking the the online archives of flight magazine I found an article on the possible use of Gatwick as another airfield for London dated 1950 (Did that go ahead????). The thing that interested me was that it stated the runways as 2 metal tracked and one grass.
Now I have never considered the use of metal track (whatever the type) on civil airfields postwar. I always assumed it was taken up after the war.
Gatwick obviously kept its track, although how it lasted 5 years after the war I couldn't guess.
Does anyone know if this was common or was Gatwick a single example?
Peter
01 Aug 2008 08:19 #2 by mawganmad
Replied by mawganmad on topic Use of metal track on civil airfields
You're not getting mixed up with metaled as in a type of concrete/tarmac construction, ie like metaled roads which replaced earth tracks?
01 Aug 2008 09:06 #3 by Robin
Replied by Robin on topic Use of metal track on civil airfields
:? Hi Mawganmad, I actually thought that, but not having the expertese of others on the site I chose to keep my mouth shut. I think that the term 'metal track' would have meant 'metalled' surface, as opposed to possible 'PSP'.
Robin.
Per Ardua ad Astra.
01 Aug 2008 18:01 #4 by Peter Kirk
Replied by Peter Kirk on topic Use of metal track on civil airfields
Me, confused? Well, yes but that's another story.
The text from January 1950 Flight is as follows :-
Three runways are provided, two being covered with steel mesh; the other is a grass strip. The dimensions are 1,400yd in the S.W.-N.E. direction and 1,200yd in the E.W. and S.E.-N.W. directions.
Apologies I should have used the terminology in the original text.
Peter
01 Aug 2008 18:16 #5 by Robin
So we are back to Perforated Steel Planking.
Robin.
Per Ardua ad Astra.
01 Aug 2008 18:27 - 17 Aug 2016 19:50 #6 by CDP
Replied by CDP on topic Use of metal track on civil airfields
Robin.
Not necessarily PSP. Don't forget, there were a number of "temporary" surfaces used including Square Mesh, Irving Grid, Bar and Rod and Sommerfield Mat.
Have a look at this thread and in one of the photos, there's a very good example of square mesh track now serving as a fence.
Chris
01 Aug 2008 19:30 #7 by Paul Francis
Replied by Paul Francis on topic Use of metal track on civil airfields
The artificial runways in the UK were either of these:
PSP = Pierced Steel Planking
Sommerfeld Track (not Sommerfield)
Channel Track
PBS = Prefabricated Bitumen Surfacing
Bar and Rod Track
Army Track
SMT = Square Mesh Track (BRC Track)
Irving Grid
01 Aug 2008 19:50 #8 by mawganmad
Blimey seems odd to use any of these systems at a fairly major airport operating large passenger aircraft type in the 1950s. It was renowned pre-war, especially for its modern terminal and underground links, seems post-war things were slow to get going again.
01 Aug 2008 20:19 #9 by Paul Francis
Not necessarily used at Civil Airports Mawganmad
01 Aug 2008 22:11 #10 by Robin
:wink: I'm learning, I see that PSP can be either Perforated or Pierced Steel Planking, I have also seen the term 'Marsden Matting' used.
Robin.
Per Ardua ad Astra.
