Airfield Pipe Mines
07 Jan 2015 10:08 #1 by superplum
Airfield Pipe Mines was created by superplum
For those that may be interested, have a look here at the second document:
www.gov.uk/government/publications/foi-r...ncing-5-january-2015
07 Jan 2015 11:01 #2 by Engimaneer
Replied by Engimaneer on topic Airfield Pipe Mines
That's really interesting to see. Will have a browse later thank you.
I remember when the police and MOD sent Stubbington and Lee On The Solent into lockdown between 9am-5pm every Monday for a few weeks to remove the mines found during construction work at HMS Daedalus.
The traffic became a nightmare as there was an exedous to beat the lockdown those days.
07 Jan 2015 11:13 #3 by mbriscoe
Replied by mbriscoe on topic Airfield Pipe Mines
I can remember when it seemed to be quite common to hear on the BBC radio Travel News that roads around an airfield in the South of England would be closed for a week or so.
07 Jan 2015 12:12 #4 by PETERTHEEATER
Replied by PETERTHEEATER on topic Airfield Pipe Mines
Interesting document. At St Eval we (RAF Bomb Disposal) found a number of empty 'pipes' beneath runways. It was not part of our remit and we were looking to take the runway lighting cable into safe custody:wink:
Also, at Weston Zoyland (1966) we found similar pipes some of which appeared to be 'charged'. AM were informed and, in due course and 'expert' arrived and pronounced that they were cable ducts. Since we were in the process of liberating the lighting cable we knew darned well from knowledge gained on that and previous projects that they were not to do with runway lighting. As far as I know there was no further action.
Blasting gelatine was used in many pipe mines and as it ages exudes sensitive oils increasing the risk if recovery is attempted. Removal of a complete pipe from under a runway slab would be, I think, by using a contact vibrator to loosen adhesion along the tube length and mechanical withdrawal using a tracked vehicle.
07 Jan 2015 19:57 #5 by SimonGee
Replied by SimonGee on topic Airfield Pipe Mines
David J. Smith's book 'Britain's Military Airfields' tell us that apparently altogether about twenty airfields were 'sown' with pipe mines, including Hurn, Roborough, Exeter & Westhampnett. In August, 1944, it was instructed to remove the explosive charges from all said mines, but with the shortage of skilled personnel, some were overlooked including Shoreham, as they discovered when the runway was extended some years ago - !
04 Jan 2023 19:36 #6 by kebecker
Replied by kebecker on topic Airfield Pipe Mines
A UXO report for a solar farm at Woodbridge, may be of interest.   publicaccessdocuments.eastsuffolk.gov.uk...licDocs/01555838.pdf
05 Jan 2023 14:42 #7 by PETERTHEEATER
I get a 404 error
05 Jan 2023 18:00 - 05 Jan 2023 18:01 #8 by kebecker
try this , it should work although you will have to go to page 2 of the view associated documents link/list. publicaccess.eastsuffolk.gov.uk/online-a...tOawdm-WL5JkApD6GKfs
