Foam landings
12 Sep 2015 10:26 #1 by canberra
Foam landings was created by canberra
I watched a documentary the other night on channel five called "dangerous flights" or something like that. On it they showed a LOT airliner landing wheels up on a foam strip.
Now this got me thinking. When I joined the RAF there were two RAF airfields with the capability to make a foam strip; Manston and Leeming. Now IIRC they lost the capability in the early eighties.
Now a few questions. Were they the only two in the UK? And why only them? Im surprised there wasnt an airfield in Scotland with the capability. Why was it done away with? Cost is one possibilty Im thinking of. And I dont suppose anyones got any pictures of the kit that was used?
12 Sep 2015 11:20 #2 by Peter Kirk
Replied by Peter Kirk on topic Foam landings
I remember the Manston gear being parked up towards the western end and that appeared to be a tanker. I did see a film of the Manston foamer in action for a practice foam. It took quite a while to set it up and lay the carpet but it was able to do a wide single pass and back again for double width. I can't find the link at present.
I don't know why they stopped but i would imagine cost and clearing up would be a factor. I also doubt it would stay put in a stiff breeze?
12 Sep 2015 11:57 #3 by ancientarmourer
Replied by ancientarmourer on topic Foam landings
I seem to remember Lossiemouth had the kit in the mid 1970s when it was an MDA.
12 Sep 2015 14:08 #4 by John Anderson
Replied by John Anderson on topic Foam landings
Simple question "Were foam landings effective?". There were some instances where the aircraft missed the foamed area altogether.
In a similar vein remember discussing with a CAA Ops Inspector in the early 1990's, the requirement for a manned/fully equipped fire fighting vehicle (LWB Landrover with foam capability) to be available on a small airfield during periods of light aircraft flying training (PPL). He said that he could not recall an instance when occupants of a PPL training aircraft had been rescued alive from a post crash fire, but that lack of the capability may not look good at a Coroner's inquest.
13 Sep 2015 01:08 #5 by Graham Yaxley
Replied by Graham Yaxley on topic Foam landings
Wildenrath in the 1970s was a master diversion airfield, with a foaming capability.
I remember that sometime between 1974 and 1977 the whole station, or so it appeared, turned out to watch the laying of foam for a Buccaneer that could not get a green light for the nosewheel. The bow wave through the foam was quite spectacular. Fortunately the cause of the problem was a faulty switch and there was no damage to the crew or aircraft.
13 Sep 2015 09:28 #6 by PETERTHEEATER
Replied by PETERTHEEATER on topic Foam landings
I had just arrived at RAF Gaydon in Febuary 1959 when Victor XA 933 made a nightime wheels-up landing onto an ad hoc foam layer put down by a Pyrene Mk 6. Spectacular spark show. The aircraft was ground down to the main fuselage longerons (wiped away the radome, scanner and bomb doors) but the aircraft was rebuilt by an HP CWP and flew again.
13 Sep 2015 19:37 #7 by Radars
Replied by Radars on topic Foam landings
Wildenrath definitely had a foam laying system. About 1967/8 a Canberra with a nose wheel problem landed in the foam and at the last minute the pilot lowered the nose of the aircraft and it came to a halt safely and not much damage to the aircraft.
13 Sep 2015 22:37 #8 by mbriscoe
Replied by mbriscoe on topic Foam landings
A few in the newspapers
Canberra at Warton
[h=1]Jet bomber lands on carpet of foam[/h] The Guardian (1959-2003) [London (UK)] 14 Aug 1963: 12
A Britannia at Manston
[h=1]5-hour wait for crash landing[/h] Our Air Correspondent . The Guardian (1959-2003) [London (UK)] 21 Apr 1967: 1
A private pilot was told it would cost him £400 to land on foam at Manston so he landed wheels up at Biggin Hill
[h=1]Why pilot decided to belly-land[/h] The Guardian (1959-2003) [London (UK)] 04 Aug 1970: 5.
13 Sep 2015 23:11 #9 by David Thompson
Replied by David Thompson on topic Foam landings
I remember the Nimrod using the foam at Leeming .
Others plus some photos on this thread over on PPRuNe ;
www.pprune.org/military-aviation/500597-foam-carpets.html
23 Sep 2018 01:21 #10 by TerryClark
Replied by TerryClark on topic Foam landings
All Air Traffic Controllers had strict instructions NOT to mention how much the foam carpet would cost unless the pilot specifically asked.
