Sub Station 13241/41
12 Jun 2009 20:44 - 19 Dec 2016 13:58 #1 by P Bellamy
Sub Station 13241/41 was created by P Bellamy
Roughed-out SketchUp model of Building 65 at Deenethorpe, eventually to be added to the Technical Site master model:
This building still exists,
I'm studying wartime aerial photos to see if this example had a fence around it.
The fence and gates can always be added later if required.
12 Jun 2009 20:48 #2 by REF
Replied by REF on topic Sub Station 13241/41
So thats what it would have looked like, I was trying to visualise it before but couldn't! It is a nice image Paul, keep them coming!
13 Jun 2009 14:15 - 19 Dec 2016 13:57 #3 by P Bellamy
Replied by P Bellamy on topic Sub Station 13241/41
Thanks Richard.
Here's an air photo from mid-1944 of Deenethorpe, with the Sub Station arrowed.
I can't see any sign of a fence surrounding the building, but someone might be able to interpret it better than I:
I'm trying to work out the arrangement of the side door and its blast wall.
That panel of render visible in your photo could indicate a covered porch of some type, similar to the one on the same building at Davidstow Moor.
However, the Sub Station 13241/41 at Spanhoe (Building 10) has a long wall, which seems to be the same size as that in the air photo above.
13 Jun 2009 20:50 #4 by REF
Thanks Paul, if you come across any other photos of mine you can id then let me know!!
Do you have a wartime aerial of Spanhoe, that way you may be able to compare sizes etc from the air
27 Jul 2009 21:48 - 19 Dec 2016 13:34 #5 by REF
Sub Station 13241/41, Building 17 at Sawbridgeworth is still there too.
