Scotland county listings.
10 Sep 2021 10:33 #1 by TerryClark
Scotland county listings. was created by TerryClark
Can't seem to find listings for Hebridean islands like Stornoway and Benbecula; do they exist?
10 Sep 2021 11:02 - 10 Sep 2021 11:02 #2 by Peter Kirk
Replied by Peter Kirk on topic Scotland county listings.
Benbecula is under Invernesshire but as I'm not familiar with historic Scottish counties and their boundaries I can't say where Stornoway might be. Everything is so slow these days I gave up looking.
10 Sep 2021 16:27 #3 by mbriscoe
Replied by mbriscoe on topic Scotland county listings.
It can be very confusing!
One way to check is open a Canmore record in the area then select Administrative Areas
Council Western Isles
Parish Stornoway
Former Region Western Isles Islands Area
Former District Western Isles
Former County Ross And Cromarty
As with England, boundaries have changed periodically so can get more complicated.
10 Sep 2021 21:45 - 10 Sep 2021 21:48 #4 by netcompsys
Replied by netcompsys on topic Scotland county listings.
The definitive way to locate a place for the forum is the Gazeteer of British Place names, as described in the FAQ area of the forum
See
www.airfieldresearchgroup.org.uk/forum/h...oes-not-exist#146896
Or go direct to
gazetteer.org.uk/index
Where it will tell you Stornaway is in Ross shire
Some care is required however where it is necessary to consult the accompanying map as the location name you are referring to may be named after a place in an adjacent county...., we have had a few of those
13 Jan 2023 11:38 - 13 Jan 2023 11:40 #5 by mbriscoe
That is one reason that best to look up the county on Canmore, most airfields should have a record there, if not then inform HES and they might add a record.
This email address is being protected from spambots. You need JavaScript enabled to view it.
I find the best way to search is using PASTMAP.
As in Wales, you sometimes find only the Gaelic name is used or at least the Gaelic spelling (Ordnance Survey can be 'bad' for doing that though seem to have improved now) so a search for the English name might not find it especially is spelt incorrectly as in Stornoway above!
