Progress at the new Archive Facility: 5 June 2020
05 Jun 2020 22:45 #1 by P Bellamy
The new archive facility is coming along slowly, due to a number of factors but especially the manpower restrictions due to the lockdown.
However, we've managed to 90% complete refurbishment of the first of the seven main rooms, the Plans and Drawings Vault.
You'll recall that when we took over the building there was no electricity, most internal and external doors were missing, half the ceilings were damaged or missing and it was generally suffering from 20 years of being used as a rubbish tip. So without further ado, here's where we've progressed to so far.
The mannequin and display table will move into the Alconbury Heritage Room as soon as that gets cleared of stuff that belongs elswhere in the building, meaning the work table will be useable properly.
The room still needs a few more ceiling tiles replacing, made more obvious by the fancy new high-output, low-energy, LED lighting panels we fitted, and a lick of paint wouldn't go amiss, but it's a whole lot better than it was... :)
The following user(s) said Thank You: carnaby, Peter Kirk, PETERTHEEATER, kebecker, airfields man, Ossington_2008, Richard Austen, Bomber, DavidNelson
06 Jun 2020 13:00 #2 by PJH
Wow Paul, that's amazing. When I helped bring the last of the stuff over from the old building, it was:
a) Dark (pitch black actually)
b) Filled to the ceiling with 'stuff'.
An incredible transformation. Well done. (although I'm sure that the 'stuff' that was here is now temporarily making one of the other rooms even fuller ;) )
08 Jun 2020 10:16 #3 by Richard Austen
Replied by Richard Austen on topic Progress at the new Archive Facility: 5 June 2020
That effort reflects some damned hard work. Respect.
The legacy of heroes is the memory of a great name and the inheritance of a great example. Benjamin Disraeli.
08 Jun 2020 15:40 #4 by P Bellamy
Room 2 was the one which was completely missing it's ceiling, so has been allocated as the main store room.
I spent Sunday installing a replacement, it's a bit grubby due to the conditions in the building the components were reclaimed from but should clean up once it's all finished.
The following user(s) said Thank You: Peter Kirk, PETERTHEEATER
08 Jun 2020 18:37 #5 by Peter Kirk
Replied by Peter Kirk on topic Progress at the new Archive Facility: 5 June 2020
I saw the photos before I read the text and was going to say - Never sit beneath a well thumbed ceiling tile. I said it anyway.
How did you get on with the LED panels as I found getting the right wattage is difficult as they tend to be a lot brighter than the wattage suggests. They tried them at work before I retired and the first one tested was so bright it made the sun jealous.
