Wartime mapping website
12 Oct 2014 10:45 #1 by carnaby
Wartime mapping website was created by carnaby
Interesting website on wartime mapping, Cassini etc:
www.echodelta.net/mbs/eng-overview.php
12 Oct 2014 11:59 #2 by Peter Kirk
Replied by Peter Kirk on topic Wartime mapping website
A lot of wartime files at TNA use the map number then 6 digit grid reference. This is frustrating as you have to identify which grid or grids the map is in and then convert it to the full Cassini grid reference to then convert it to a current OS grid reference. I use this excellent online converter but when you have hundreds of these to convert it is very time consuming. It also has the Irish Grid converter on another page but luckily the modern Irish grid is the same as the wartime one, only with a single letter prefix.
www.fieldenmaps.info/cconv/cconv_gb.html
I have often wondered if there was a Google overlay for wartime grid reference squares along with modern ones as this will save converting lat/long (in its many forms) into grid references.
12 Oct 2014 13:17 #3 by carnaby
Replied by carnaby on topic Wartime mapping website
One tip I use with these converters when you don't have all the info is:
1) If you know very roughly where the site is first to get the modern NGR from 'Where's The Path', e.g. TQ 123 456
2) Put this into the converter which generates a Cassini reference wQ 462 648. This provides the vital 'wQ'
3) Then replace the '462 648 ' with the Cassini reference you need to find, and convert again which will give the correct TQ xxx yyy.
Very occasionally you will be on the boundary of either system (e.g. where 'TQ' changes to the adjacent' SU' or 'TL'). This can generate rubbish and a revised example away from the boundary is required.
12 Oct 2014 20:14 #4 by Peter Kirk
That is a very good way of taking the guess work out of it. I still had a couple that defied all attempts to locate, probably due to a typo in the first number or even the wrong set of numbers entirely. I am just starting to build a Cassini overlay for Google Earth - manually - as my skills don't allow me to join the points up accurately so when you zoom in the lines end up being a hundred yards out!
I also found an online overlay of the current OS grid and also the outlines for the Discovery & Explorer series. Sadly I left the machine and the many updates I allowed yesterday rebooted my PC so I lost the pages before bookmarking them and also about 12 grid points I had plotted!
#@#&&**~~ Microsoft
12 Oct 2014 21:16 #5 by Chris Lowe
Replied by Chris Lowe on topic Wartime mapping website
Ahh yes I've used similar phrasing after an MS reboot as well.
some of the tools here are useful www.metzgerwillard.us/EarthSurvey.html I've used range rings a few times to help with distances.
12 Oct 2014 23:01 #6 by Peter Kirk
The rings add-on looked good until I tried to use it. It seemed to want me to type in the co-ords each time rather than use those in an existing POI of which I have hundreds! I was going to use it for danger radii in GE. The instructions didn't make much sense as it didn't do what it said. Shame.
13 Oct 2014 03:36 #7 by Chris Lowe
It is a bit cumbersome but good when you get it to work, it's the only thing I've found so far that lets me draw circles in GE.
13 Oct 2014 19:12 #8 by Peter Kirk
Chris, apologies, it does work but only with the current searched location. I just pasted in a converted NGR and opened the "rings" add-on and it assumed that location. I need to play with sector arc next but the wartime angles need conversion for the shift in magnetic north, although they do quote true north which I assume is Manchester?
May have to move this to the Google Earth thread as it might be useful there.
PS I use this to convert my lists of NGRs to GE map locations. gridreferencefinder.com/batchConvert/batchConvert.php
I don't know how to convert the map pin to something else though. It saved me many hours and from my Excel master I just create the whole lot again in seconds after minor updates!
