Enquiry, building type/use?
17 Oct 2016 19:08 - 18 Oct 2016 08:05 #1 by redmist
Enquiry, building type/use? was created by redmist
Hello gents, perhaps someone could enlighten me regarding these remains I came across whilst photographing some remains? (York, Clifton Moor). My initial guess is that the bulk of what I found represent an area of dispersed accommodation and/or admin buildings but not being a 'regular' on such sites this (to me) unusual and unexpected construction has got me scratching my head. It seems there was some kind of (building?) that had a series of pillars either inside it, or underneath it supporting a raised floor. But all that is speculation on my part. Hopefully the photos show enough to help identify the size and extent of the original construction. From memory the pillar fragment was at least 4 inches in diameter. Grid plan pattern of pillar bases. Over to you and thanks in advance for any input :-)
York 054a
York 056a
York 057a
York 061a
18 Oct 2016 08:37 #2 by Paul Francis
Replied by Paul Francis on topic Enquiry, building type/use?
I do not know the answer but I have seen something similar at Dunkeswell though they may not be the same:
Pairs of earthenware pots are spaced at seven ft centres and 6ft apart, are filled with concrete and support steel studs. The studs are not threaded along their entire length. NGR: ST 1361 0741
The following user(s) said Thank You: redmist
18 Oct 2016 09:50 #3 by carnaby
Replied by carnaby on topic Enquiry, building type/use?
My initial guess is that the bulk of what I found represent an area of dispersed accommodation and/or admin buildings...
Where was this site, Redmist ?
18 Oct 2016 14:44 #4 by Peter Kirk
Replied by Peter Kirk on topic Enquiry, building type/use?
I wonder if the supportsituation are to keep 5 floor of the ground to keep something dry or rodent free?
18 Oct 2016 17:00 #5 by redmist
Replied by redmist on topic Enquiry, building type/use?
Thanks for the input so far.
Carnaby - I will add some more photos etc to the main airfield entry. They might help with specifics.
Peter Kirk - such a purpose did occur to me too, but on an RAF airfield site? I was rather hoping that these were a common known item and an answer would have been straight forthcoming, however it does make for a bit of interest. Although I suppose the area may have been subject to flood or general wet, but so many other adjacent building pads don't have these features. Including ones directly alongside. Now if this had been a Roman site ..... :-)
18 Oct 2016 17:13 #6 by Peter Kirk
That's it! An RAF hypocaust :)
18 Oct 2016 22:20 #7 by PETERTHEEATER
Replied by PETERTHEEATER on topic Enquiry, building type/use?
It was usual to raise timber hutting off the ground.
18 Oct 2016 22:30 #8 by redmist
I had thought of that one too, but the surviving section of broken pillar was at least 3 feet high, maybe more? That seems quite extreme, unless there was a known flooding issue. York does have this problem these days. I don't have the local knowledge to answer whether it had it back then, but if this area was inundated to that kind of depth then the rest of the airfield would be one large swimming pool :-) But raised buildings do seem likely explanations.
