what type of hangar
18 Nov 2020 17:07 - 19 Nov 2020 14:42 #1 by robin bird
what type of hangar was created by robin bird
What type of flying boat hangar? see attached
19 Nov 2020 13:56 #2 by PETERTHEEATER
Replied by PETERTHEEATER on topic what type of hangar
The photograph appears to be of a 1934 Type 'C' Hangar. Most flying boat base had the Type 'F' Hangar with side opening doors.
MOD published a hangar identification document some years ago. It can be found on-line but here is a typical link:
pdf4pro.com/view/world-war-ii-hangars-gu...fication-5854ef.html
19 Nov 2020 14:43 #3 by netcompsys
Replied by netcompsys on topic what type of hangar
Where is this and when was this photo taken ?
19 Nov 2020 23:03 #4 by PJH
Replied by PJH on topic what type of hangar
If it's for flying boats, I'm going to guess Type B at Pembroke Dock.
19 Nov 2020 23:24 #5 by carnaby
Replied by carnaby on topic what type of hangar
That would have been my guess too. I note the picture filename is hangarrhu_
I'm not sure what sheds Helensburgh / Rhu had, though a photo on this page looks similar to the OP picture.
www.helensburgh-heritage.co.uk/index.php...ge/military?start=14
20 Nov 2020 08:18 #6 by John Anderson
Replied by John Anderson on topic what type of hangar
Rhu/Helensburgh is in Robin's patch!
20 Nov 2020 10:50 #7 by PETERTHEEATER
Britain from Above (you have to Register to zoom an image) :
britainfromabove.org.uk/en/image/SAW026580
At 2 o'clock on the edge of the image cab be seen a multi-pitch structure which, I think, is the RAF Rhu hangar. The image is dated 1949
The following user(s) said Thank You: carnaby
20 Nov 2020 20:41 - 20 Nov 2020 20:49 #8 by carnaby
Well spotted. The roof structure is identical to the two remaining hangars at Pembroke Dock. There is also something like a Bellman / T2 alongside.
I can;t find anything on any on-line maps, and am not entirely sure where the site is exactly.
21 Nov 2020 09:45 #9 by PETERTHEEATER
The RAF Rhu slipway and hangarage was located here:
wtp2.appspot.com/wheresthepath.htm?lat=5...grat=None&rgrat=None
In Robin's photograph it would appear that the aircraft is sitting at the top end of the slipway with the hangar behind.
Rhu was a Marine Aircraft Experimental Establishment which is probably why that aircraft prototype was there. Since 'B' Type hangars featured at other flying boat bases such as Pembroke Dock it would be a fair assumption that the Rhu hangar too was a 'B' but too little detail to be conclusive.
21 Nov 2020 10:07 #10 by PETERTHEEATER
On reflection, the profile in the photograph could be that of a 1934 pattern Type 'C' or a Type 'B'. Although the Rhu site dates back to WW1, when was the subject hangar erected? If it was not until 1938/39 why build a 1934 pattern 'C'? Was open door width and internal capacity a main factor? Operational aircraft in numbers would have been moored out on the trots coming ashore only for maintenance and repair whereas 'one-off' prototypes might be hangared for safety and security (thou shalt not see) except when out for flight. Just thoughts.
