Mystery Object
21 Jul 2013 21:20 #1 by SXS
Mystery Object was created by SXS
I came across this object at the Little Easton Lodge special open day today (WORLD WAR II DAY & CONCERT). It had been unearthed from somewhere on the Little Easton/Dunmow airfield site, but no one has yet been able to identify what it is.
The trigger on the hand-grip may be a clue, but it doesn't look like the "paddle" grips used to control either the Martin Power Turret (dorsal guns) or the Bell M-6 Mount (tail guns) that were used on the B-26 Marauders based there. Perhaps it's something used on the Stirlings that were there later.
There appears to be a small motor and some gearing within the unit, along with various electrical connectors.
Can any of you knowledgeable folk please identify the mystery object from the following photographs ?
13 Mar 2017 14:14 #2 by WILLIAMARNOLD
Replied by WILLIAMARNOLD on topic Mystery Object
some of the wiring looks similar to a heating element
Long ago and far away
13 Mar 2017 16:45 #3 by Peter Kirk
Replied by Peter Kirk on topic Mystery Object
Or part of a rheostat?
14 Mar 2017 18:29 #4 by WILLIAMARNOLD
that seems more likely with the gear cog and the thumb switch ?operating a rack and pinion sort of thingyou could get a voltage control system similar to a scalelextix hand set perhaps for controling an electric motor such as one used to swivel a turret perhaps.
The following user(s) said Thank You: SXS
15 Mar 2017 06:17 #5 by PETERTHEEATER
Replied by PETERTHEEATER on topic Mystery Object
As Peter said, the zig-zag wire would have been wound around a circular former, probably ceramic since it would need to be insulated. The former has disintegrated leaving the nichrome wire unwound. A spring-loaded contact would have 'wiped' around the wire varying the circuit resistance for a control function.
Having a natural interest in gun turrets I have some knowledge and reference sources on the subject but cannot yet match the control to a gun installation. Turrets usually had a single stick control or 'handlebar' controls with twin grips so it may not be related to armament.
15 Mar 2017 11:19 #6 by Peter Kirk
The trigger would imply some element of control over the amount of power. Would some sort of instrument require a trigger control?
