Hedon Aerodrome ??????
18 Aug 2013 19:38 #1 by ojays
Hedon Aerodrome ?????? was created by ojays
I recently came across this photo but question it's location!
Having read the history of Hedon Aerodrome, I cannot see that this photo would have been of Hedon due to it's proximity to Hulls Barrage Balloon Squadrons, and I haven't read anywhere of the PSP decking ever having been used there!
Can anyone shed any light on the pic?
[IMG]/community/130614=13435-Hedon or Not.jpg[/img]
Thanks
Gregg
19 Aug 2013 07:56 #2 by Ossington_2008
Replied by Ossington_2008 on topic Hedon Aerodrome ??????
The OA code on the Beaufort indicates 22 Sqn, who were based at North Coates Apr 40 to Jun 41. Is the surface actually PSP? I don't think it was in use then. Could it be Somerfeld track?
19 Aug 2013 08:20 #3 by jorge
Replied by jorge on topic Hedon Aerodrome ??????
Isn't PSP narrower sectional pieces than that shown on the photo?
19 Aug 2013 08:26 #4 by Peter Kirk
Replied by Peter Kirk on topic Hedon Aerodrome ??????
It must be North Coates as you cannot operate a torpedo unit without the proper facilities for torpedo preparation and maintenance, all of which required special buildings. The PSP is an effect, I suspect, cause by tyre marks made by the towing vehicle. The torpedoes also appear to be a mix of live and practice, assuming the dark tipped ones are red and the others are not yellow and we can't see the difference. Never did find out what red and yellow heads meant :)
I assume the "near Hull" reference was a wartime caption and slightly less vague than somewhere in England. I would also say that Brough is out of the question for the torpedo reason and I doubt torpedoes were brought in specially for a photo.
19 Aug 2013 12:15 #5 by PJH
Replied by PJH on topic Hedon Aerodrome ??????
Wasn't Hedon shut for the duration of the war? (and indeed afterwards)
19 Aug 2013 12:53 #6 by ojays
Replied by ojays on topic Hedon Aerodrome ??????
Thanks for your response guys. This backs up what I thought, that it couldn't have been Hedon.
19 Aug 2013 13:00 #7 by Peter Kirk
I think it was. Someone called Paull picked it up and moved it somewhere else after the war sometime.
Oblique 1930's views of Hedon are on the Britain From Above website. Sample here - www.britainfromabove.org.uk/image/epw031624
26 May 2017 22:04 #8 by bloodhound
Replied by bloodhound on topic Hedon Aerodrome ??????
North Coates without a doubt, taken in 1940. 22 Sqdn Beauforts and 812 Sqdn Swordfish. Just on of a set of around 4 set piece photographs taken by the Air Ministry
01 Jun 2017 20:46 #9 by Kevin Aeronca
Replied by Kevin Aeronca on topic Hedon Aerodrome ??????
Hangars look right for North Coates, as does the QA code, but I am surprised nobody has mentioned Catfoss, which was the home of No 2 (Coastal) OTU. What type hangars were there?
01 Jun 2017 23:07 - 02 Jun 2017 08:51 #10 by netcompsys
Replied by netcompsys on topic Hedon Aerodrome ??????
Brian should know !
here are two more from the same series from the IWM
Mark XI aerial torpedoes being taken out on trolleys towards a Bristol Beaufort Mark I, L4516 'OA-W', of No. 22 Squadron RAF at North Coates, Lincolnshire. Shortly after this photograph was taken, L4516 was destroyed when it stalled after a night take-off from North Coates and hit the ground near Marshfield, detonating the mine it was carrying.
"The media for this item are free to reuse for non-commercial purposes under the IWM Non Commercial Licence © IWM (CH 1851)"
Beaufort L4516 of No 22 Squadron with an array of torpedoes at North Coates in early December 1940. This aircraft was lost later in the month when it crashed on take-off.
"The media for this item are free to reuse for non-commercial purposes under the IWM Non Commercial Licence © IWM (CH 1854)"
In the second photo you can clearly see that the "perforations" are rubber tyre marks on concrete
