Armourers required to identify this please
12 Jan 2014 11:04 - 05 Apr 2017 14:44 #1 by netcompsys
Armourers required to identify this please was created by netcompsys
Converted to a table apparently, but can anyone provide more info please
Kevin
12 Jan 2014 12:50 #2 by PETERTHEEATER
Replied by PETERTHEEATER on topic Armourers required to identify this please
It's self-identified:). It is a Tail Unit for a post-war bomb. The multi vane rotor on the back end was removable by pressing the centre pin and sliding it off the shaft. The rotor spun the shaft as the bomb fell from the aircraft and a 'fork' on the opposite end armed the bomb pistol ready for striking a detonator on impact. Obviously its main function was to stabilise the bomb as it fell.Some versions could have a DDA fitted (Device, Delay Arming) which was a clockwork escapement preventing the arming shaft from rotating until the bomb had dropped a safe distance away from the aircraft. The latter much used on V- Bombers and Canberra aircraft.
That version, I think, was for external carriage on fighter bombers. Superplum may add more.
12 Jan 2014 20:47 #3 by superplum
Replied by superplum on topic Armourers required to identify this please
Nice one PTE! All I dare add is that the 107 was, as stated, mainly used by the V and Canberra force for ballistic (freefall) use. Later fast-jets used the 114 which, in the main, appeared identical but was stronger because of the additional stresses encountered and also catered for the fuzing electrical supply (no pistols unless you were Navy).
13 Jan 2014 06:42 #4 by PETERTHEEATER
Then the 114 must have been installed on the Mk 10 1000 pound Bomb with the EL Fuzing pockets?
And here's the 107 being prepared for DDA fitment in a Missile Preparation Shed (new name for a Fuzing Point shed) at RAAF Butterworth 1961. I'm on the camera.
Just realised that was over fifty years ago!
Note how we tidy Armourers kept our shoes shiny despite the toil!
13 Jan 2014 11:37 #5 by superplum
Occasionally but, because the fast-jets did relatively little medium level work, 117's (retarded) were mostly used. Mk10's were not plentiful but were consumed in lieu of disposal. The fuzing pockets, being different sizes and needing N1/N2 adaptors, required a little "work" with a wooden drift and hammer to push the EL connector backwards to make space.
Call those shoes clean?
15 Jan 2014 12:48 #6 by netcompsys
Replied by netcompsys on topic Armourers required to identify this please
Thanks guys
