WW2 Defensive Structure?
19 Jun 2015 17:00 #1 by ww2ni
WW2 Defensive Structure? was created by ww2ni
I located this yesterday covering a Railway Line at Portballintrae in County Antrim.
I believe it is a WW2 Defensive Structure - A pedestal for a Weapon to protect the Line.
It is similar to those I have seen at Airfields and so I am wondering if you forks can assist.
Have you seen anything similar?
For a Gun??
Any Help would be much appreciated.
Andy
Attached files [IMG]/community/161266=23163-railway defence one.jpg[/img] [IMG]/community/161266=23164-railway defence three.jpg[/img] [IMG]/community/161266=23165-railway defence two.jpg[/img]
19 Jun 2015 18:12 #2 by SimonGee
Replied by SimonGee on topic WW2 Defensive Structure?
An interesting find - !
I can see why it may be considered some sort of weapons mount, but there are a number of things which don't tie in with that possibility. The concrete appears to have been finished, i.e., it has a smooth finish but there are no signs of any sort of bolts or holdfasts which would be required to hold a weapon in place. The walls are much too low to be of any use, but that could have been remedied with sandbags. The quality of the casting is very poor. What does anyone make of the 'cutouts' in the visible corners of the walls - ?
This appears to have been made to mount something - but what exactly - ?:confused:
19 Jun 2015 19:50 #3 by mbriscoe
Replied by mbriscoe on topic WW2 Defensive Structure?
Does not explain the walls but could the block have been for mounting something like a range-finder or the aircraft spotting things the ROC used? That type of thing needs a solid mount to keep steady.
20 Jun 2015 10:55 #4 by ww2ni
Replied by ww2ni on topic WW2 Defensive Structure?
I think the Cut- Outs would have been for camouflage.
21 Jun 2015 18:14 #5 by SimonGee
Another point that has occurred to me; why a five sided structure when a square or rectangular enclosure would have been quicker and easier to cast / build - ?
21 Jun 2015 18:16 #6 by SimonGee
And why did this need a five sided enclosure when a square or rectangle would have been much simpler and quicker to build - ?
22 Jun 2015 07:34 #7 by Harboda77
Replied by Harboda77 on topic WW2 Defensive Structure?
Nearest approximation I could locate on line.
www.pillbox-study-group.org.uk/index.php.../pentagonal-pillbox/
Assume the narrow gauge railway line was a post conflict addition ?
22 Jun 2015 09:30 #8 by ww2ni
Hi,
Thanks very much.
No - The narrow gauge railway was in use during the War and runs between Portrush and Bushmills which is interesting as there were a number of Ranges and Camps in this area at that time.
Andy
