Dornier Do 17
08 May 2013 21:34 #11 by Kevin Aeronca old
Replied by Kevin Aeronca old on topic Dornier Do 17
I seem to recall that a Do 17 lingered on the RAF Bicester dump until about 1960. A shame nobody saved it; that would have been a lot less bother reconstruct.
Was anyone as amused as me by the cliche-ridden press release from the RAF Museum? Apparently recovering an aircraft from under the sea is a "ground-breaking" operation!
11 May 2013 08:38 #12 by Peter Kirk
Replied by Peter Kirk on topic Dornier Do 17
I would like to point out that part of the Goodwin Sands was used as a bombing range, probably 1944/5. I wonder how that was cleared post-war :)
10 Jun 2013 19:11 #13 by REF
Replied by REF on topic Dornier Do 17
Its out of the water!
www.bbc.co.uk/news/uk-22846645
25 Aug 2013 19:54 #14 by CDP
Replied by CDP on topic Dornier Do 17
Just spotted on BBC News 24.
Dornier 17: The Fall and Rise of a German Bomber (30 mins)
Available on BBC iPlayer for next five days (as of 25/08/13): www.bbc.co.uk/programmes/b020sj6g
If that link becomes invalid for any reason, try entering the programme title in the BBC iPlayer search box on the home page: www.bbc.co.uk/iplayer/
Repeated: Mon 26/08/13 at 10.30 a.m. or Mon 26/08/13 at 14.30
Probably only available in the UK.
Chris
25 Sep 2016 22:36 - 27 Nov 2016 22:05 #15 by Sparky67
Replied by Sparky67 on topic Dornier Do 17
A few months ago I was fortunate to be invited to an excellent talk by Darren Priday from the RAF Museum's Sir Michael Beetham Conservation Centre on the recovery of the Dornier Do 17Z 5K + AR from the Goodwin Sands, and a subsequent visit to see it in its current state. Below are a few photos from the visit.
Fuselage from the nose, inverted.
Fuselage, inverted.
Controls on port-side cockpit wall.
Upper forward gun sight.
One of the engines.
Prop hub assembly. The condition of the cylinder heads can be seen on the engine behind.
Wing centre section inverted
Undercarriage and tyre (wing is inverted)
E Bl1 blind-landing azimuth beam receiver on its mounting frame, with a freq still showing in the LH window... The receiver covers 30.0 to 33.3MHz
Unknown ID plate
The following user(s) said Thank You: Peter Kirk, ianbache, John Anderson
27 Nov 2016 21:55 - 27 Nov 2016 22:32 #16 by Sparky67
A few more (radio-related) images from the Do.17Z...
ID plate from the mounting frame for the FuG.10 EK and EL HF/LF Radio Receivers
Remains of the E.Bl2 blind-landing receiver, used to pick up the outer- and inner-marker beacons on 38MHz
An electronic relay and insulator, use not yet identified
An electronic transformer and choke from the E.Bl1 receiver
An electronic valve, possibly from the E.Bl1 or E.Bl2 receiver
Case from the AAG.2 or AAG.3 Antenna Tuner
Insulated rotary switch / contactor arm from the AAG.2 or AAG.3 Antenna Tuner
Component (LF RF detector?) from the AAG.2 or AAG.3 Antenna Tuner
28 Nov 2016 07:45 #17 by Dietmar Morley
Replied by Dietmar Morley on topic Dornier Do 17
Great pics Sparky, thanks for sharing.
Your picture of an unknown ID plate (Wechselstrom-Geber) is a Tachometer Generator which is a device for measureing rotation speed on a turning shaft. I have no idea what this would have been attached to.
28 Nov 2016 10:08 - 28 Nov 2016 10:09 #18 by Sparky67
Thanks Dietmar. Tachometer Generator is much better than my translation of 'Frequency Giver'! The MBCC has a comprehensive set of (Luftwaffe) handbooks on the aircraft so hopefully some more research will determine what this is and where it was fitted.
