Bristol Brabazon
14 Aug 2014 04:50 #1 by Harboda77
Bristol Brabazon was created by Harboda77
Found the following statements in what must be an early to mid 1950's book entitled " Marvels of Modern Science " by Odhams Press Ltd, Long Acre London.
This aircraft is designed specifically as a trans-oceanic air-liner to provide fast travel for a large number of passengers at one time.
It is fully pressurized, high altitude, long-range monoplane with a wing span of 230 ft.
Power is provided by eight Bristol Centaurus 18-cylinder air cooled engines.
As the engines are totally enclosed in the inner wing, it will be possible for inspection and servicing to be carried out while the aircraft is in flight.
Passenger and crew accommodation is arranged mainly on one deck with a half-deck rise over the wing for a dining saloon, lounge bar, kitchen and servery.
In the main cabin aft, provision will be made for a cinema projector and radio for passengers entertainment.
My Father took me to see it and all that I can remember was being impressed with the size of it and if I've remembered it correctly it had been one of the first aircraft with all powered controls however however I don't recall the statement about in flight inspection and servicing ?
14 Aug 2014 06:33 #2 by Guest
Replied by Guest on topic Bristol Brabazon
Didn't they turn the prototype into firewood?
14 Aug 2014 06:35 #3 by PETERTHEEATER
Replied by PETERTHEEATER on topic Bristol Brabazon
My uncle took me to Farnborough in 1950, I think, where the prototype flew in the display. Very impressionable at age ten it was the sheer size of it that I remember and the noise of all those engines. Much later as I went into aviation I looked back using such books as were then available to try and understand the engine arrangement but never found anything detailed enough. The chord thickness of the wing was sufficient to give enough height to enable physical access by a man but, apart from replenishing oil tanks I can't what other tasks might be accomplished in-flight. The Centarus engine was a fairly conventional piston radial and air cooled so being 'buried' in the wing would have required ram air cooling arrangements. Presumably the engines, in pairs, were side by side coupled through a common gearbox to drive contra-rotating props.
14 Aug 2014 08:23 #4 by ChrisTheAncient
Replied by ChrisTheAncient on topic Bristol Brabazon
My somewhat latent memory of Brabazon associations was going past Filton airfield and seeing what looked like a ginormous shed on the end of one of the hangers. Apparently, the Brabazon was so big that it wouldn't fit in the hanger and the extension was there to cover the tailplane.
14 Aug 2014 10:21 #5 by Ossington_2008
Replied by Ossington_2008 on topic Bristol Brabazon
I wasn't around at the time, but a few decades later, I found old, I think, "Eagle" annuals, or something similar, that showed cutaways of an engineer working deep into a wing root in something akin to a wind tunnel 'doing in-flight maintenance'. It has just occurred to me that the intake/cooling inlets must have had closeable doors to make this possible, and fly below oxygen height etc.
14 Aug 2014 11:05 #6 by netcompsys
Replied by netcompsys on topic Bristol Brabazon
I think this unlikely as the hangars was built to accommodate the manufacture of the Brabazon, was used for the Concorde production line with multiple airframes and similarly for Britannia refurbishments
Having been inside during the concorde period I can assure you they were dwarfed by the hangar and that it is HUGE!
edit 1 =->
heres a photo of the Brabazon coming out of the hangar
www.airteamimages.com/bristol-brabazon_G...any_82193_large.html
edit 2 =->
I have just realised that if you were going past Filton by road you would have been unlikey to see the doors of the hangar as they are on the side away from the runway and road. The hangar is a truncated T with 3 sections
see
www.flashearth.com/?lat=51.516195&lon=-2...&z=16.5&r=0&src="msa"
14 Aug 2014 14:52 #7 by netcompsys
I wasn't around at the time, but a few decades later, I found old, I think, "Eagle" annuals, or something similar, that showed cutaways .....
Aeroplane and Flight published cutaways of the Brabazon...
15 Aug 2014 06:21 #8 by PETERTHEEATER
I just found a copy of the Flight article on the Centaurus engine commenting particularly on the cooling arrangements on the engine itself although not the Brabazon installation. There was a crankshaft driven forced air fan pushing air through individual cylinder shrouds and the front cylinder bank ran slightly hotter than the rear.
15 Aug 2014 08:36 #9 by ChrisTheAncient
Kevin
Thanks for some of those details and picture.
However, the 'garden shed' attachment was on the runway side of the hanger I was referring to and I imagine was way before Concorde was even a twinkle in a designers' eye! So goodness knows what it was or what it was for. After all, it was early/mid-50's and [apply Zummerset accent] I were but a lad [accent]!
Anyone remember that attachment and the reason?
15 Aug 2014 09:37 #10 by Aeronut
Replied by Aeronut on topic Bristol Brabazon
The covered weighbridge (Note it is NOT a Hangar) at Boscombe Down is of the same type as the Filton Hangars, which is not surprising as it was built for the Brabazon project. Its size only really struck home with me when I saw it containing a dh106 Comet, a TriStar, Canberra Mk 9, Havard and an Airship 500 - and it didn't appear cramped.
