Bristol Brabazon
15 Aug 2014 14:27 #11 by canberra
Replied by canberra on topic Bristol Brabazon
I believe that it was possible for the Flight Engineer to get in to the wing on the Sunderland to fix engine snags in flight.
15 Aug 2014 21:31 #12 by YellowPinkie
Replied by YellowPinkie on topic Bristol Brabazon
17 Aug 2014 09:44 #13 by alertken
Replied by alertken on topic Bristol Brabazon
I suggest we not pay too much attention to the in-flight point. It was a PR slant to grab attention. Brabazon wing was derived from an 11/42 Bid for a very big bomber: on Heavies (not less than one) engine-per-sortie might well give trouble, so some form of access would be helpful. The bomber lapsed, but Bristol won its adaptation as (to be) Brabazon, in part as they were idle (though with zero expertise in big structure), in part because they were already funded into propellor-turbines: Mark II Brabazon was the intended variant, with Theseus as UK's means of defeating ginormous US schemes (Convair XC-99, Lockheed Constitution, more). They all died because size was only wanted as means of getting payload into the Pacific Theatre: after VJ Day, economy/reliability were wanted, which 6 or 8 engines did not offer.
17 Aug 2014 09:58 #14 by carnaby
Replied by carnaby on topic Bristol Brabazon
... this aircraft is designed specifically as a trans-oceanic air-liner to provide fast travel for a large number of passengers at one time.
Just discovered that the design began as the Bristol '100-ton bomber', from 1942. Spec was 300 mph cruising with 10,000 lb bomb load with a range of 4,000 miles. Original design had a butterfly tail.
Source: Bristol Aircraft since 1910. Putnam
10 Apr 2016 10:47 #15 by netcompsys
Replied by netcompsys on topic Bristol Brabazon
Seen in Bristol's M-shed during August 2011
A piece of the fuselage ( the only remaining bit?)
model difficult to phot behind two lots of glass
Brabazon Hangar under construction
10 Apr 2016 10:50 #16 by netcompsys
a less dark version of the fuselage photo above
22 Jun 2018 10:01 #17 by WILLIAMARNOLD
Replied by WILLIAMARNOLD on topic Bristol Brabazon
As a child when Coventry still had an aerospace industry i used to visit the Herbert Art Gallery and Museum and stand by the wheel of a Brabazon which was proudly displayed.
Long ago and far away
