Lockheed Martin F35 Lightning II
17 Jul 2016 10:31 #41 by Harboda77
Replied by Harboda77 on topic Lockheed Martin F35 Lightning II
John Collingridge article today in the ST Business section details that 15% of every F35 are built in Britain and that we are gradually ordering more to reach two squadrons by 2025.
It also indicates that the total production run is projected to be in the order of 3000.
17 Jul 2016 16:54 #42 by mbriscoe
Replied by mbriscoe on topic Lockheed Martin F35 Lightning II
Is that 15% only ones for the RAF or all F35s?
17 Jul 2016 17:38 - 17 Jul 2016 17:53 #43 by Harboda77
F35 web based statement ( www.f35.com/about/variants/f35b )
UNITED KINGDOM INDUSTRIAL PARTICIPATION
Built in the United Kingdom, Delivered to the World
As the program’s only Level 1 partner, the United Kingdom has garnered tremendous economic benefits from the F-35.
British industry will build 15 percent of each of the more than 3,000 planned F-35s, generating significant export revenue and GDP growth.
The program is projected to create and support more than 24,000 jobs across every region of the United Kingdom.
The F-35B STOVL operation is made possible through the Rolls-Royce patented shaft-driven LiftFan® propulsion system and an engine that can swivel 90 degrees when in short takeoff/vertical landing mode.
Because of the LiftFan®, the STOVL variant has smaller internal weapon bay and less internal fuel capacity than the F-35A.
It uses the probe and drogue method of aerial refueling.
F-35B aircraft have been delivered to the U.S. Marines and the U.K.
U.S. STOVL aircraft are stationed at the first operational F-35B base, Marine Corps Air StationYuma, Arizona, and Marine Corp Air Station Beaufort, South Carolina, where F-35B training is taking place.
The first UK F-35Bs are located at RAF 17 Squadron, Edwards AFB, California,
10 Nov 2016 20:43 #44 by Harboda77
MOD (?) Sealand to be the Global Repair Hub for F35's ?
ukdefencejournal.org.uk/uk-chosen-global-f-35-repair-hub/
04 Apr 2017 14:08 - 04 Apr 2017 14:10 #45 by ColinArmfield
Replied by ColinArmfield on topic Lockheed Martin F35 Lightning II
I found this article fascinating
Quite long but tremendous background information.
F-35 Continues to Stumble.
www.pogo.org/straus/issues/weapons/2017/...nues-to-stumble.html
The following user(s) said Thank You: Paul Francis, Harboda77
04 Apr 2017 16:16 #46 by Peter Kirk
Replied by Peter Kirk on topic Lockheed Martin F35 Lightning II
The Americans make a plane that will perform better than the F-35 in its current state. I think it is called an AV8B, perhaps we should buy some?
04 Apr 2017 17:01 - 04 Apr 2017 17:02 #47 by John Anderson
Replied by John Anderson on topic Lockheed Martin F35 Lightning II
Some second hand AV8s would be ideal!
24 Mar 2018 08:38 #48 by Harboda77
Apparently the F35 is also being assembled at the Cameri AFB in Italy. ( ICAO code: LIMN)
Recent Industry Quote: Cameri is the home of the only final assembly plant outside the United States for Lockheed Martin’s F-35B.
A Joint Strike Fighter, a stealthy jet that can take off and land vertically.
Across from the plant’s runway stands another futuristic manufacturing plant using Avio Aero’s 3D-printing factory for making sleek turbine blades for Boeing’s next-generation 777X jets.
Another European ( local content ) contributor.
26 Mar 2018 09:34 #49 by stevie
Replied by stevie on topic Lockheed Martin F35 Lightning II
F-35 in the hover at RIAT 2016 -
Steve
The following user(s) said Thank You: 698
26 Mar 2018 12:31 #50 by Peter Kirk
Was there ever a YF-35 or are they all X prefix now? Farnborough 1976 was full of Y prefixes e.g. YF-17 and YC-15
