Runway Construction mishaps and oddities
21 May 2020 10:23 #1 by Tony H
Gents - posting this as I have to admit my knowledge on this specific topic is "below par" . . .
I am aware that prior to any actual airfield construction, several surveys would have been made to ensure the ground was suitable and adjacent high ground was considered when choosing runway directions etc. I'm also aware of some "oversights" after construction had started - e.g. Pocklington's "original" main runway - abandoned 2/3rd's built when they realised that if used it would take aircraft directly over the adjacent town at a dangerously low height . . .
Was it a simple case of demand exceeded suitable/logical availability - hence airfields being built in less than ideal locations? (like Acaster Malbis)
Linked to this, Breighton appears to be unique in that, due to the proximity of the River Derwent at the western end, extensions had to be built on all other runways almost immediately after construction had been completed - subsequently leading to it (possibly?) being the only airfield where all the runways met at a central intersection and not the standard "A" layout?
Are/were there any other airfields where runways all met at a central point - noting possibly Finmere comes close to the Breighton example?
Many thanks!
Tony
21 May 2020 11:54 - 21 May 2020 11:54 #2 by Peter Kirk
Replied by Peter Kirk on topic Runway Construction mishaps and oddities
The ones that actually cross that come to mind are:
Dyce
Elvington
Hampstead Norriss
Silloth
Predannack (3 of the 4)
But there are some that are very like:
Condover
Ouston
Scorton
Greenham
Harwell
St Eval
There must be others and probably many in their earlier grass surface only where the landing strips were much wider so they probably don't count. I included Predannack but perhaps it, along with most Fleet Air Arm airfields should be discounted as four or more runways vastly increase the potential for three to cross at the same point. If we had vast amounts of land we could have used the system they had in North America.
21 May 2020 13:17 #3 by kebecker
Replied by kebecker on topic Runway Construction mishaps and oddities
Saltby is also very close
21 May 2020 15:22 #4 by Peter Kirk
We also had a thread on incomplete runways where they were started but never completed , either due to time , cost or changing requirements.
21 May 2020 15:33 - 21 May 2020 15:34 #5 by netcompsys
Replied by netcompsys on topic Runway Construction mishaps and oddities
were you thinking of this topic?
Airfields that never were
www.airfieldresearchgroup.org.uk/forum/a...er-were?start=0#2951
21 May 2020 16:11 #6 by Tony H
Replied by Tony H on topic Runway Construction mishaps and oddities
Many thanks for the replies - clearly a few more than I thought had all runways intersecting at one point . . . guess demand exceeded logic from time to time!
Tony
21 May 2020 18:20 - 21 May 2020 18:23 #7 by Peter Kirk
No, although Millisle was the rare example. It was airfields like Wattisham, Balado Bridge, Fordoun etc. that had stubs stated but halted at an early stage which was here:
www.airfieldresearchgroup.org.uk/forum/a...mpleted-runways#1629
That topic never got as far as explaining why each airfield had its final runway aborted.
23 May 2020 10:20 #8 by carnaby
Replied by carnaby on topic Runway Construction mishaps and oddities
...That topic never got as far as explaining why each airfield had its final runway aborted.
A long time ago! I read somewhere that the 'official' conclusion was that WWII airfields didn't need three runways, two would have been sufficient, (FAA stations excepted).
That said there are quite a lot of airfields where the three runways are far from the ideal 60 degrees apart.
The following user(s) said Thank You: Tony H
22 Aug 2020 10:08 #9 by canberra
Replied by canberra on topic Runway Construction mishaps and oddities
Thats down to the topography, Leuchars in wwii only got 2 runways a third would have ended up going in to Tentsmuir forest. Of course it still only has 2 runways and when Cranwell got its runways in the 50s it only got 2.
22 Aug 2020 12:24 #10 by Ossington_2008
Replied by Ossington_2008 on topic Runway Construction mishaps and oddities
Valley had three in my day (1978-79), which meant six barriers to service. Seems the shortest one is now being lifted according to Bing Satellite coverage. I wonder if Hawks are more tolerant of side winds than Gnats and Hunters were?
