Temporary steel planking or reinforcement on airfields
25 Jun 2020 12:30 - 25 Jun 2020 12:34 #1 by netcompsys
Pierced plank type, or Pierced Steel Plank (PSP)
Bar and Rod Type Track
( From a display board at the Radar Museum, Neatishead)
25 Jun 2020 12:32 #2 by netcompsys
From and older (2008) post by Paul Frances
The artificial runways in the UK were either of these:
PSP = Pierced Steel Planking
Sommerfeld Track (not Sommerfield)
Channel Track
PBS = Prefabricated Bitumen Surfacing
Bar and Rod Track
Army Track
SMT = Square Mesh Track (BRC Track)
Irving Grid
25 Jun 2020 14:05 #3 by PETERTHEEATER
Replied by PETERTHEEATER on topic Temporary steel planking or reinforcement on airfields
During my working life I had to lift about a 1000 square meters from a former aircraft movements area. It had been laid during the '50s on ground which had been only roughly prepared. Consequently aircraft weight had bent sections into slight hollows. Lifting it was hard dirty work especially in Middle East heat and almost every plank required hand dressing with club hammers because we had to use it to floor a supply storage area. Laying it was a chore.
Three years later when clearing an old warehouse, one of my Supply colleagues discovered over eight thousand new PSP planks hidden behind a high wall of boxes along with over 100 new (but now deteriorated and unusable) aircraft tyres. During the period that these tyres would have been usable we had had multiple aircraft NORS-G (Not Operationally Ready - Grounded). A pointless investigation found that the items had been delivered very early in the main contract and stored but not brought on charge.
25 Jun 2020 15:24 - 25 Jun 2020 15:25 #4 by PETERTHEEATER
Off topic but of interest.
Further to my post (below) about PSP and tyres being found in a storage shed, in the same shed hidden behind truss-high boxes was an Austin 1 ton truck, new, covered in a thick layer of sandy dust and resting on flat and perished tyres. Delivered March 1970, found on site June 1978 :)
25 Jun 2020 18:35 #5 by IanDDavidson
Hiding. That's an old trick. Find something, hide it away and if no-one asks about it for a while and it doesn't show up on record cards, one night the "fairies" just take it to a better place. Normally material things can be converted by the " fairies ", using magic, into other things like beer and fags.
My uncle is dead now, but when in Greece in WW2 they took over a Petrol dump. He noticed from the marks in the sand that the Germans had been lifting the barbed wire and rolling drums of fuel out of the compound, and as he found out, selling it to the local "fairies". As you might expect me to tell you, his troop did exactly the same.
The following user(s) said Thank You: carnaby
25 Jun 2020 20:00 #6 by carnaby
PSP and Bar-and-Rod were both American designs. The former was very successful, the latter not so being difficult to manufacture and problematic to install. It was used at Brackla, Elgin, and Stormy Down (among possible others). A lighter version was also produced. PSP weighed 5.25 lbs / sq ft, B&R was 3.9 or 1.9 lbs / sq ft; In comparison the much-used Sommerfeld was 1.2 lbs / sq ft
Source: Maj RRW Grigson, BSc AMICE in The Engineer in War
01 Jul 2020 14:40 #7 by kebecker
seen at the Palm Springs Air Museum a few years ago, I am assuming PSP?
01 Jul 2020 15:14 #8 by PETERTHEEATER
Yes, that's PSP but from what I can see those strips have been laid for show, edge to edge. Easy Peasy. To cover an large area properly the 'planks' had to be laid like bricks in a 'bond' pattern which required a team working together with various tools and gloved hands onto a graded and rolled surface. Very satisfying once completed and the broken and crushed fingers treated. New planks were relatively easy but recovered 'used' planks a real challenge.
01 Jul 2020 16:10 #9 by kebecker
Just looked on GE and it is no longer visible so as you say was likely for show. From memory the stone surface it was on was well consolidated and was home to a phantom which did not seem to be sinking into the gravel!
01 Jul 2020 18:12 #10 by Peter Kirk
I think I posted something in the Boscombe Down thread as they used PSP or similar to make a few of the spectacle hardstands to the same design as the concrete ones. They even showed up on aerial photos a "vague" spectacle hardstands and were marked on the 1944/5 RSP as temporary.
Finally another possible repeat - my granddad's garage was a concrete pre-fab design and one of the panels, after about 20 years (1970's) had spalled and revealed PSP as the reinforcement.
