× A place to post photos (just a handful please) of air shows through the season and add any discussion.
Hawker Hunter crash at Airshow.
31 Aug 2015 13:58 #61 by Engimaneer
Replied by Engimaneer on topic Hawker Hunter crash at Airshow.
I personally think the CAA reacted to the media in the worst way possible.
Instead if re-assuring the non aviation-informed public that vintage aircraft ARE maintained to the same standard as most other aircraft, they told the public it will be 'reviewed'.
The restrictions placed on vintage jets flying aerobatic manouvers over land is understandable, but lets hope there is a long term solution and that is only temporary.
As others have said, many aircraft in every day service are much older than the Hunter in question, with many many more hours on the clock.
Structural issues/corrosion can be brought on by age, but in terms of other systems, age should not matter if it meets the standard set.
I know of a fleet of civil registered aircraft built in the 60's-70's still flying many many hours a month in very regular use.
Plus when you talk about aviation safety and vintage jets, no-one points out how dangerous puddle jumpers are with a PPL pilot on board. The AAIB staff always tell me that a tour of their hangars would put most off of a single-engine puddle jumper for life.
31 Aug 2015 14:29 #62 by mbriscoe
Replied by mbriscoe on topic Hawker Hunter crash at Airshow.
Pilots are always quick to criticise any non-pilots who speculate on the cause of the aircraft accident so I think the same should apply to non-AAIB people speculating on what the AAIB might have learnt from wreckage, crash scene and analysis of records and previous incidents.
I certainly would not like to just write it off as 'accidents happen' if I was investigating the accident and temporary restrictions seem quite reasonable whilst they do their investigation.
It might be unlikely but if there was another accident involving innocent members of the public completely uninvolved with the airshow then I would expect there would a major public reaction against airshows.
31 Aug 2015 17:53 #63 by Peter Kirk
Replied by Peter Kirk on topic Hawker Hunter crash at Airshow.
The trouble is the public feed off the press (see Winkleigh thread) and the truth is what they say it is, especially on subjects they have little knowledge of. I stopped reading the nationals papers about 30 years ago after a friend of mine was appallingly misquoted to suit the story and many subsequent incorrect "facts". Someone once said, I think in a computer mag, that if you if you can't trust the stories on something you know about how can you trust them on the ones you know nothing about.
05 Sep 2015 11:49 #64 by canberra
Replied by canberra on topic Hawker Hunter crash at Airshow.
According to the press the AAIB have stated that there was nothing mechanically wrong with this aircraft.
05 Sep 2015 14:27 #65 by Peter Kirk
That was very quick! I wonder if the AAIB were referring to the maintenance log and "the press" assumed?
05 Sep 2015 14:32 #66 by P Bellamy
Replied by P Bellamy on topic Hawker Hunter crash at Airshow.
They may be reporting that, but that's not quite what the AAIB preliminary Special Bulletin actually says...
Engineering Investigation
Recorded data
The aircraft was not fitted with a flight recorder and no flight path information was recovered from the aircraft GPS.
Two image recording cameras were mounted within the cockpit. One was located on the aft cockpit bulkhead between the two seats, giving a partial view of the pilot and instrument panel, and a view through the cockpit canopy and windscreen. To date no abnormal indications have been identified. Throughout the flight, the aircraft appeared to be responding to the pilot’s control inputs. The other video camera was mounted at the base of the windscreen, looking over the nose.
Cockpit imagery is being analysed to help understand the final manoeuvre in more detail and to provide system status information.
Pre-flight technical activity
The aircraft was operated on a CAA-issued Permit to Fly and its current Certificate of Validity was valid until 10 March 2016. There were no technical defects recorded in the aircraft Technical Log.
The aircraft and its two under-wing tanks were fully fuelled before the flight. Ground crew reported that the pre-flight checks and engine start were normal and that the safety pins for the pilot’s ejection seat had been removed and placed in the stowage provided prior to departure to arm the seat and its associated systems.
The full bulletin can be read here:
assets.digital.cabinet-office.gov.uk/med...c/S3-2015_G-BXFI.pdf
05 Sep 2015 14:48 #67 by Peter Kirk
Wait till the press realise what an ejector seat does and see the word "armed"! I fear more inaccurate reporting will follow.
05 Sep 2015 16:56 #68 by airfields man
Replied by airfields man on topic Hawker Hunter crash at Airshow.
Why did it have to be fully fuelled to do a brief display. Maybe it was going on somewhere else after, but surely it could have landed then re-fuelled.
05 Sep 2015 17:55 #69 by P Bellamy
Fuelled at North Weald prior to planned displays at a number of different shows that day I'm led to believe.
05 Sep 2015 23:33 #70 by MartynJ
Replied by MartynJ on topic Hawker Hunter crash at Airshow.
Bournemouth was also on the agenda for a display that day, so i understand. So consider transit flights between venues, the hunter holding for its display slot etc . Why the aircraft is fully fuelled starts to be better understood.
"There's Nothing going on, and you're missing it"
