Rotating Images
11 Jul 2016 20:46 #1 by Dietmar Morley
Rotating Images was created by Dietmar Morley
There's been a few issues with pictures being rotated when posted from a mobile phone.
Apparently this relates to the way phone OS's code their image sizes. Some applications (and clearly this is one) then reads the information in a transposed form, in other words they read the X-axis dimension as the Y-Axis and vice versa. Thus the photo gets rotated on upload. I think this happens when the phone is held in a particular orientation as it doesn't happen every time.
We're looking into it to see what, if anything can be done. In the meantime if this problem does occur, the best solution is to download the photo to PC first, rotate it 4 times or modify it in some way, re-save it and then upload.
12 Jul 2016 10:06 #2 by PETERTHEEATER
Replied by PETERTHEEATER on topic Rotating Images
Modern technology! I used to get that problem after six pints of Worthington E :blink:
12 Jul 2016 21:44 - 12 Jul 2016 21:45 #3 by Dietmar Morley
Replied by Dietmar Morley on topic Rotating Images
Drinking aside...... B)
It seems that the problem is that mobile devices save the images using the standard landscape orientation, but then add some ‘EXIF’ information into the image code that tells the viewer the rotation of the image. Unfortunately when the images are uploaded and resized for browser, this information is ignored and stripped from the images (stripping this data is standard for web images as it contains quite a bit of information that could cause privacy concerns if made available).
I've just done a test and discovered that if, when taking the picture, I hold my iphone in landscape orientation with the home button to the right (which is possibly the natural way to hold for right handed people), the picture uploads fine.
If I hold the phone vertically in portrait orientation then the image is rotated left into landscape thus the image ends up on its side (unless viewing on my iPhone, in which case it shows fine).
If I hold the phone with the home button to the left the picture is rotated either left twice or right once. Either way it ends up upside down.
So, the trick is, if uploading directly from your iPhone make sure you take the picture in landscape orientation with the home button to the right! Otherwise you will need to post process on your PC/Laptop (by making some small adjustment before re-saving) before upload.
Meanwhile we'll keep looking for a fix.
12 Jul 2016 22:45 #4 by Peter Kirk
Replied by Peter Kirk on topic Rotating Images
Oops! Didn't see this until after I replied to the TEST post!
13 Jul 2016 08:59 #5 by PETERTHEEATER
Is this the reason why we see so many portrait format videos on TV and the web? They were 'filmed' in landscape but the phone software rotated it?
13 Jul 2016 11:04 #6 by Dietmar Morley
No, they were filmed in portrait as it is the easiest way to hold a phone in one hand. Filming when holding your phone in landscape gives full width widescreen coverage.
13 Jul 2016 12:23 #7 by PETERTHEEATER
Thanks Dietmar.
I thought that might be the case. We get a lot of phone videos on Thai TV News of 'on the spot' action and it is very irritating viewed in portrait format. A case of educating the camera person!
13 Jul 2016 12:42 #8 by Peter Kirk
I think those that shoot portrait only view in portrait, typically on the phone they took it on. A bit strange as some shoot in HD to view on a 5" screen - utterly pointless. Real life is landscape for most. I am surprised that the "smartphones" can't detect that the shooting orientation is the way it should be stored, irrespective of where the home button is.
13 Jul 2016 13:04 #9 by Dietmar Morley
They do Peter K, that's point. They add the EXIF data that tells the smart phone which way around it is, but this gets stripped off on upload. That's why we have the problem.
I only point out the position of the home button as a work around to avoid upside down photos.
13 Jul 2016 16:27 #10 by Peter Kirk
Sorry, what I was trying to say is that the phone should re-orientate it so that with or without the EXIF data it would be the right way up. I assume those wanting it to be upside down on purpose would be in the minority. I can understand it with cameras as all my TNA photos from the camera stands are upside down but they date from the era of prints :)
Not sure what happened here though :)
