Google Earth thread!
18 May 2008 19:18 #1 by REF
Google Earth thread! was created by REF
On this link there is a KML file you can download that will pin point most UK airfields
www.homepages.mcb.net/bones/06ai ... ukmenu.htm
If anyone has any interesting airfields bits on google earth then post them up on here!
Richard
EDIT: Link changed, now here:
www.homepages.mcb.net/bones/UK_Airfield_Catalogue/ukmenu.htm
09 May 2009 16:29 #2 by Peter Kirk
Replied by Peter Kirk on topic Google Earth thread!
It has been mentioned elsewhere but in case you haven't seen it the latest Google Earth has a roll back facility to show previously published Aerial Photos. For the UK this is around 1999 but don't forget coverage was poor then! Luckily when you zoom out you can see the aerial overlays.
There are aerials dating back to the 1940's in places like the US but I only found one covering some unkown location in Washington State and it was very small. Good luck with that one!!
One GE Scotland appears to have been updated and coverage now includes the Getmapping stock. The usual holes are still there and two that I would like to see are Dumfries and Edzell but I fear by the time they get coverage it will be too late.
On the plus side Kirkwall is now visible and I know a lot of you have been waiting for that. Also for you "Strips in ths Isles" folks a lot of the Orkney airfields are also visible but the Orkney coverage is limited so misses a few WW2 sites including the one that is rude in Manchester (specifically Bury but I won't go into that right now!)
If anyone has spotted anything else please post as although some will probably have found it other might not.
09 May 2009 22:44 #3 by OneEighthBit
Replied by OneEighthBit on topic Google Earth thread!
Any chance the forums mods can add "KMZ" and "KML" files to the list of allowed attachments and set say a 500k limit?
I've got a couple of cracking Google Earth files I want to share.
10 May 2009 09:00 #4 by Peter Kirk
That would be very useful especially to go with the lists in the as built section.
10 May 2009 09:41 #5 by REF
Replied by REF on topic Google Earth thread!
OEB - I have changed the maximum file size to 500k, it might be worth trying to upload a file on a new audit thread and see if it works, any problems let us know!
10 May 2009 14:53 #6 by OneEighthBit
When I try and attached the KMZ files directly I get a "File extension KMZ not allowed" message, so get around this I put the two KMZ files into a ZIP file. :)
I can't honestly remember where I found these and there is some overlap but they are probably the most comprehensive lists I've seen. Nicely sorted they cover not just airfields/aerodromes but SLG's, ELG's, decoys, HAA sites, etc, etc.
10 May 2009 18:10 #7 by Peter Kirk
Many thanks. You are right it is by far the best I have seen. As it enables you to choose what to view you dont get a mass of differnt flags.
I am now removing the others I have that overlap.
Incidentally I was amazed at how many AA sites are still visible after all these years. A quick look at UKAerialphotos.com shows some of them in the postwar photos but others are mysteriously covered in the only cloud for miles!
11 May 2009 03:12 #8 by OneEighthBit
Yeah I mentioned the "convenient" clouds in the thread I made about photo/map censorship. :D
11 May 2009 12:30 #9 by REF
I'm not sure how to allow the kmz files, I'll have another look but I don't think there is an option to allow certain file types. The zip file works well though
27 Aug 2009 08:10 #10 by PETERTHEEATER
Replied by PETERTHEEATER on topic Google Earth thread!
I am comfortable using GE but accept that there may be better 'viewers' out there.
But, managing Placemarks saved in .kmz or .kml is a real bind since it has to be done manually.
I have found only one utility available on-line which has the ability to 'sort' a limited number of files in a single folder but can't really get it to work satisfactorily.
Can anyone recommend alternatives?
