Gun Post
30 Dec 2018 17:19 #1 by Garth Barnard
Gun Post was created by Garth Barnard
Does anyone have any pictures or drawings of what an airfield 'Gun Post' looked like?
Cheers,
Garth.
30 Dec 2018 19:04 #2 by kebecker
Replied by kebecker on topic Gun Post
There are two at Polebrooke, the link is meant to take you to post 27 of the thread. I took these at least ten years ago and have not been back since so my memory of the dimensions is vague.
www.airfieldresearchgroup.org.uk/forum/n...brook?start=20#10627
The following user(s) said Thank You: Garth Barnard
30 Dec 2018 19:47 #3 by Garth Barnard
Replied by Garth Barnard on topic Gun Post
Thank you for that, much appreciated, but it's not what I was expecting at all. Your pic's show something that is quite substantial, whereas I thought it would just be something that a Bren attached to.
30 Dec 2018 20:18 #4 by kebecker
I agree these are way to big for a single Bren, I need to locate the RSP I hav e but I recall that one is marked and called a gun post. I had a quick look at the image here. www.americanairmuseum.com/sites/default/files/eh/eh-101.jpg. and both appear to be visible ion 1946.
30 Dec 2018 21:49 #5 by Garth Barnard
Fantastic picture - could look at it for hours!
31 Dec 2018 07:21 - 31 Dec 2018 10:35 #6 by PETERTHEEATER
Replied by PETERTHEEATER on topic Gun Post
Cheers,
Garth.
Garth,
The term 'Gun Post' refers to the complete installation which varied dependent on local terrain and ingenuity. Often a shallow circular pit with a filled sandbag perimeter wall in the centre of which was a gun mount set in concrete
The simplest version on UK airfields used to mount a Light Machine Gun such as Lewis Gun, Bren Gun was little more than a metal socket set in concrete into which a vertical tubular post was set. The LMG was mounted on top giving a 360 degree rotation and near vertical elevation.. More elaborate mounts existed.
Try using the Forum Search function (select to search text not just the title) and type in MOTLEY.
See image here: www.google.com/search?q=bren+gun+aa+moun...imgrc=qRTucg4EwXeJFM:
There were mounts too for 20mm calibre guns usually Hispano or Poulsten or Oerlikon
Here's a twin Lewis mount at Mildenhall. Tidy gunpost too!
www.iwm.org.uk/collections/item/object/205210779
31 Dec 2018 10:37 - 31 Dec 2018 10:37 #7 by Garth Barnard
Ah, I did use the search facility, but hadn't heard of the word/description of Motley before - thank you!
I managed to find the exact spot of the 'Gun Post' and the attached photo's are what I found:
The following user(s) said Thank You: PETERTHEEATER, Jeff Hawley
31 Dec 2018 12:12 #8 by PETERTHEEATER
What are the dimensions of that foundation Garth?
31 Dec 2018 17:41 #9 by Garth Barnard
A pure guess, but I'd say 3ft x 3ft.
I'll go back in the next day or so and measure it up.
01 Jan 2019 03:52 #10 by PETERTHEEATER
Thanks. I was looking at the ring of bolts probably the 'holdfast' for the gun mount implying a heavier calibre than a LMG.
