Drawing number?
27 Sep 2009 16:28 #1 by NJR
Drawing number? was created by NJR
I bet no one can provide a drawing number for this.
A drainage pipe? That's what we thought until closer inspection.
The bottom is filled with concrete and a gun mount of some description set into it. These are at Kings Cliffe, near an E pen on the southern taxy way which leads to the hangar base.
Two more can be found in situ at the south of the airfield near the BHQ and cantalever pillbox. Note metal mesh in front.
Gun mount just visible.
NJR
"When you stop remembering you start forgetting"
27 Sep 2009 16:42 #2 by Paul Francis
Replied by Paul Francis on topic Drawing number?
Nope not yet!
27 Sep 2009 17:43 #3 by Denis
Replied by Denis on topic Drawing number?
The metal mesh is American Bar & Rod tracking Noel. The mount inside the concrete section is the same type of mount as highlighted in the 'Motley mount' thread!
27 Sep 2009 18:06 #4 by Paul Francis
The action man figure in the second pic sadly is not Buzz lightyear but our very own CDP!
28 Sep 2009 09:29 #5 by PETERTHEEATER
Replied by PETERTHEEATER on topic Drawing number?
And the internal diameter is approximately.....?
28 Sep 2009 12:35 #6 by CDP
Replied by CDP on topic Drawing number?
You beat me to it with these Noel!
Internal diameter? About four feet, thereabouts. What drew us to them in the first place (the pair in the copse near the BHQ and cantilever pill-box) was the fact that the external ground level is considerably higher than the floor and central mount.
The "exposed" pair, for want of a better expression, give an idea as to the construction of the floor - rough rubble/concrete with the internal floor skimmed smooth. Quite what the little hatch thing is, well - any ideas? There's a recess around it, indicating some sort of plate was fitted. A drain cover over a soak-away, perhaps?
Chris
PS - wasn't doing much in the way of buzzing or lightyearing that day Paul!
28 Sep 2009 19:42 #7 by Peter Kirk
Replied by Peter Kirk on topic Drawing number?
Could be sewer/cess pit tops with the inspection hatch, adapted for a more warlike activity. No need for expensive custom built jobs.
28 Sep 2009 20:08 #8 by hypoboy
Replied by hypoboy on topic Drawing number?
There are also a couple more apparently in situ at the side of one of the fighter pens just" here.
Sorry to thread hijack, but whilst discussion's centred around King's Cliffe, can anyone confirm that this " is a searchlight battery? Found it the other week whilst wandering around, but it's not on the DoB database. Pics 1 , 2 , 3 and 4 if helps?
28 Sep 2009 22:06 #9 by Paul Francis
Looks like the D/F station and an air-raid shelter, not searchlight
28 Sep 2009 23:18 #10 by P Bellamy
Replied by P Bellamy on topic Drawing number?
The structure in question is arrowed here on the 1947 air photo:
Although at first glance it appears to be an octagonal M&E Plinth, the shadow thrown in the air photo indicates whatever was inside the walls was the same height as the Blister Hangars nearby.
A DF mast could well be the explanation.
