Boeing B-52 Stratofortress
16 Nov 2009 19:46 #1 by carnaby
Boeing B-52 Stratofortress was created by carnaby
Just been to an interesting lecture by Rolls Royce on Flight Testing. The speaker mentioned that the B52 is likely to be the first aircraft with a service life of 100 years.
The floor is open.
16 Nov 2009 20:45 #2 by daveg4otu
Replied by daveg4otu on topic Boeing B-52 Stratofortress
Well, in spite of trying for years the USAF have not found a replacement that does the job as well for a manageable price.
There are also a fair number of KC-135s fast approaching their half century....not far behind the B-52s.
Given that the USAF presumably have a good stock of many spares, (having broken up several hundred early B52 models at Davis-Monthan)...the main requirement is for supply of spares not covered by the Reclaim program.
If that can be achieved I suppose there is no real limit to how long they can keep flying - they are not doing large numbers of hours per year.
16 Nov 2009 22:25 #3 by mawganmad
Replied by mawganmad on topic Boeing B-52 Stratofortress
The floor is open.
Really, the prototype first flew in 1952, so the type would have to be in service for another 43 years to meet that centenery, the current H models were built in 1961-62 so they will have to be around for another 52 years.
Damn, I won't even be alive to prove the speaker wrong!
I believe it is due to be retired in 2040. It is a tremendous aircraft, especially given that it was designed in the 1940s (that's probably where the hundred years thing comes from), you would think the sheer size and thus airframe flexing etc would have seen it retired along time ago.
Long live the BUFF!
16 Nov 2009 22:31 #4 by Peter Kirk
Replied by Peter Kirk on topic Boeing B-52 Stratofortress
2040 is the date I heard a few years ago. The hundred years refers to the type and not any particular airframe which will be a bit of a "Triggers Broom" when retired. The Ion Pulse engines will not be original (Whoops I let the cat out of the bag).
One big problem for 2040 is the lack of fuel depending on which doomsday theory you believe.
16 Nov 2009 22:36 #5 by mawganmad
You may jest, but there is one B-52 that is the only jet aircraft to be flying on an 'alternative' fuel!
16 Nov 2009 22:57 #6 by Brothmark
Replied by Brothmark on topic Boeing B-52 Stratofortress
you guys know too much for non-American civilians! The Buff will live forever
16 Nov 2009 23:01 #7 by Peter Kirk
Named after the famous Royal East Kent Regiment I assume :)
17 Nov 2009 06:14 #8 by PETERTHEEATER
Replied by PETERTHEEATER on topic Boeing B-52 Stratofortress
The limiting factor on most airframes is fatigue life. That, in turn, is directly affected by the way that the aircraft is operated.
Like civilian aircraft, the usual B52 flight envelope (I assume) is a simple take-off, climb, level cruise, descend and land with no real hard manoeuvrings. The original fatigue life, as defined by Boeing, has probably been revised a number of times through the use of real-time data obtained from retrofitted on-board operational load measurement equipment.
Yes, it could probably go to a 100 year life but by that time it would be un-manned and remotely controlled as a UAV. But, I suspect that weapons development will be so advanced in 20 years time that anything flying aerodynamically can be brought down at a whim!
What price the ballistic version of the DC-3/C-47?:lol:
17 Nov 2009 08:21 #9 by mawganmad
You might want to do a search under 'B-52 low-level'! Why they can barrel that baby in so low, its jet exhaust frying chickens in a barnyard!*
The footage of the B-52 on low-level test, that loses all of its tail fin and still makes a fairly normal landing is particularly impressive!
I've seen it somewhere that the B-52 was one of the first designs where aeroelasticity of the wing structure was a major consideration.
*Name the film? - not you PNK!
17 Nov 2009 11:09 #10 by daveg4otu
Whilst the B52 may be capable of treetop level missions - I really doubt whether those are much of a likelihood nowadays when most missions would (I guess) involve " stand-off" weapons released miles away from the target and guided in, or the Vietnam style carpet bombing from 40,000ft.
So I would agree with Peter's assesment of the "usual " flight envelope.
Time to create page: 0.082 seconds
