Runway / Railway Safety Signalling
13 Mar 2011 09:42 #1 by Paul Francis
Runway / Railway Safety Signalling was created by Paul Francis
On a recent bit of research into Oakington I came across the problem of aircraft on finals, coming into contact with railways and trains, overshooting the runway and fouling the railway or even crashing onto railway lines having not made it to the runway. The earliest reference I found to this was in WWII at Burn, but other schemes were in operation at Middleton St George (installed in 1946) and Full Sutton.
Does anyone know any more, or have pictures of these trip wires?
Oakington
The position of the NE and east ends of the main and subsidiary runways were far too close to the railway track and as runway sterilisation was out of the question, it was proposed in March 1952 that a system of trip wires (at ten feet height plus an intermediate one) should be installed on each side and within the funnel approaches. The trip wires would ensure that trains would have adequate warning, so that they could pull up in time when an aircraft had crashed on the railway line. The runway was only a short distance outside the Up Home signal of Oakington station box and a scheme agreed in March 1953 included utilizing this signal to protect the runway. Trip wires were installed, which on being severed by an aircraft, would automatically place the Home Up signal to danger and its relative Up Distinct to caution and would prevent the signalmen from accepting an Up train from the rear signal box. The severing of the trip wires would also ring a warning bell in the signal box which would enable the signalmen promptly to stop a Down train likely to foul any obstruction resulting from a flying accident by putting his Down signals to danger; the Down Starting semaphore signal would also be locked in the On position when the trip wires were severed. There was also direct telephone communication between the control tower and the signal box which had been installed during WWII.
17 Mar 2011 13:02 #2 by Barney
Replied by Barney on topic Runway / Railway Safety Signalling
Hi Norwichpaul,
If you ever get chance to visit the Bressingham Gardens museum they have the signalling diagram from Oakington signal box on display. It shows the trip wire arrangement.
Cheers,
Barney.
17 Mar 2011 13:22 #3 by Paul Francis
Replied by Paul Francis on topic Runway / Railway Safety Signalling
Thanks Barney.
17 Mar 2011 13:34 - 31 Oct 2017 20:55 #4 by REF
Replied by REF on topic Runway / Railway Safety Signalling
There is a plaque on the Oakington Village Sign Commemerating Alan Bllom, founder of the Bressingham Museum, this would explain why it is at Bressingham. I will visit next week and have a look at it.
17 Mar 2011 18:23 #5 by David Thompson
Replied by David Thompson on topic Runway / Railway Safety Signalling
Teesside Airport has these trip wires on its NE threshold of 24/06 along a stretch of the Stockton to Darlington railway line and I understand they have been in place since its days as RAF Middleton St George . They can be clearly seen from the A67 road which runs parallel to the railway .
17 Mar 2011 18:37 #6 by canberra
Replied by canberra on topic Runway / Railway Safety Signalling
I wonder if Leuchars or any other airfield had something similar? I know the tower at Woodvale has a large button that when hit it cuts the electric off on the railway line to the east of the airfield.
17 Mar 2011 19:06 #7 by Paul Francis
Since 1946 David re-my post No.1 above.
18 Mar 2011 07:33 #8 by PETERTHEEATER
Replied by PETERTHEEATER on topic Runway / Railway Safety Signalling
I don't fully understand this.
Taking Middleton St George as an example, to give warning of an aircraft crashing on the railway during approach to Rwy 024 (i.e. from NE to SW) the trip wires would have to be on the opposite side of the A67 away from the railway. Were they strung between poles? Presumably they had to be replaced after being hit. For an aircraft landing on Rwy 06 (i.e SW to NE) and overrunning onto the railway, the tripwires would need to be between the runway end and the railway. So, were there two sets?
18 Mar 2011 09:38 #9 by David Thompson
From memory the trip wires are on both sides of the track , it's a double track , and are suspended above the height of the rail on pole's . If an aircraft lands on the railway it breaks the wires and the train signals turn to red . I guess there must also be some form of repeater signal which goes to the nearest signal box or control room ? I'll go and have a closer look and try and take some photographs .
18 Mar 2011 13:26 #10 by ricasso
Replied by ricasso on topic Runway / Railway Safety Signalling
It wouldn't have been much use in the case of the aircraft that crashed into the railway embankment along side Radlett Aerodrome in the early 60's, I believe Canberra knows more about this one.
